mjpeg_streamer 这个程序为何运行出错?
这个程序为何运行出错?
SSID和KEY应该填写你的Wi-Fi路由器的名字和密码。
https://singtown.com/learn/49596/
看视频,你应该运行ap的代码。
AP的可以运行,我是问这个为什么不能运行?
是我的路由名和密码啊!
因为这个代码没有及时更新,s.settimeout(0) 改为了s.setblocking(True)
下面的代码是可以正常运行的。
# MJPEG Streaming # # This example shows off how to do MJPEG streaming to a FIREFOX webrowser # Chrome, Firefox and MJpegViewer App on Android have been tested. # Connect to the IP address/port printed out from ifconfig to view the stream. import sensor, image, time, network, usocket, sys SSID ='' # Network SSID KEY ='' # Network key HOST ='' # Use first available interface PORT = 8080 # Arbitrary non-privileged port # Reset sensor sensor.reset() # Set sensor settings sensor.set_contrast(1) sensor.set_brightness(1) sensor.set_saturation(1) sensor.set_gainceiling(16) sensor.set_framesize(sensor.QQVGA) sensor.set_pixformat(sensor.GRAYSCALE) # Init wlan module and connect to network print("Trying to connect... (may take a while)...") wlan = network.WINC() wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK) # We should have a valid IP now via DHCP print(wlan.ifconfig()) # Create server socket s = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM) # Bind and listen s.bind([HOST, PORT]) s.listen(5) # Set server socket to blocking s.setblocking(True) def start_streaming(s): print ('Waiting for connections..') client, addr = s.accept() # set client socket timeout to 2s client.settimeout(2.0) print ('Connected to ' + addr[0] + ':' + str(addr[1])) # Read request from client data = client.recv(1024) # Should parse client request here # Send multipart header client.send("HTTP/1.1 200 OK\r\n" \ "Server: OpenMV\r\n" \ "Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n" \ "Cache-Control: no-cache\r\n" \ "Pragma: no-cache\r\n\r\n") # FPS clock clock = time.clock() # Start streaming images # NOTE: Disable IDE preview to increase streaming FPS. while (True): clock.tick() # Track elapsed milliseconds between snapshots(). frame = sensor.snapshot() cframe = frame.compressed(quality=35) header = "\r\n--openmv\r\n" \ "Content-Type: image/jpeg\r\n"\ "Content-Length:"+str(cframe.size())+"\r\n\r\n" client.send(header) client.send(cframe) print(clock.fps()) while (True): try: start_streaming(s) except OSError as e: print("socket error: ", e) #sys.print_exception(e)
