  • 我调用了圆形识别例子,想通过wifi方式将直径传输到电脑,我把这两个结合了,请问如何修改参数?
    • import sensor, image, time, network, usocket, sys, json
      yellow_threshold = ( 0, 8, -9, -0, 0, 10)
      Reset sensor
      Set sensor settings
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      #识别历程添加
      Init wlan module in AP mode.
      You can block waiting for client to connect
      def response(s):
      client, addr = s.accept()
      client.settimeout(2.0)
      # Read request from client
      data = client.recv(1024)
      # Send multipart header
                  "Server: OpenMV\r\n" \
                  "Content-Type: application/json\r\n" \
                  "Pragma: no-cache\r\n\r\n")
      # FPS clock
      # Start streaming images
      #添加圆形识别例子
      k=260
      k2=0.1154
      if len(blobs) == 1:
          b = blobs[0]
          Lm = (b[2]+b[3])/2
          length = K/Lm
          #print(length)
          #print(Lm)
          size=k2*Lm
          print("直径为",size)
      #传输数据
      client.send(json.dumps(blobs))
      client.close()
      # Create server socket
      # Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
          # Set server socket timeout
          s.settimeout(3)
          response(s)
      except OSError as e:
          s.close()
          print("socket error: ", e)
          #sys.print_exception(e)
