这个代码需要如何优化才能提速?
# 红外RGB565跟踪示例 # # 这个例子展示了使用OpenMV Cam进行红外RGB565跟踪。 import sensor, image import time #from numba import jit from pyb import UART import json import utime import pyb #EXPOSURE_TIME_SCALE = 0.1 thresholds = (100,100,0,0,0,0) # thresholds for bright white light from IR. TimeBin = [0,0] TimeBox = [0,0] sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking sensor.skip_frames(time = 10) sensor.get_exposure_us()#以毫秒为单位返回曝光率 sensor.set_auto_exposure(False,exposure_us=100)#设置曝光 #sensor.set_auto_exposure(False, \ # exposure_us = int(current_exposure_time_in_microseconds* EXPOSURE_TIME_SCALE)) clock = time.clock() # Tracks FPS. uart = UART(3,115200) def find_max(blobs): max_size=0 for blob in blobs: if blob.pixels() >max_size: max_blob=blob # max_size = blob.pixels() return max_blob while(True): #utime.sleep_ms(50) #for i in range(0,6000): clock.tick()# Track elapsed milliseconds between snapshots(). img = sensor.snapshot()#binary([thresholds], invert=True, zero=True) # TimeBox[1]= TimeBox[0] # TimeBox[0] = utime.ticks_ms() #deal = utime.ticks_diff(TimeBox[0],TimeBox[1]) #print("deal :",deal) # start = utime.ticks_ms() blobs=img.find_blobs([thresholds],pixels_threshold=200,area_threshold=250) for blob in blobs: output_str = json.dumps(blobs) max_blob=find_max(blobs) img.draw_rectangle(max_blob.rect(),color=(255,0,0)) output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy()) print('you send:',output_str) uart.write(output_str+'\n') # print("Initial exposure == %d" % sensor.set_auto_exposure()) #current_exposure_time_in_microseconds=sensor.get_exposure_us() #sensor.set_auto_exposure(False, \' # exposure_us = int(sensor.get_exposure_us() * EXPOSURE_TIME_SCALE)) print("New exposure == %d" % sensor.get_exposure_us()) TimeBin[1] = TimeBin[0] TimeBin[0] = utime.ticks_ms() delta= utime.ticks_diff(TimeBin[0], TimeBin[1]) print('duration:',delta) print("FPS:", clock.fps()) #img.draw_cross(blob.cx(), blob.cy()) else: print('not found!') 说要优化代码来提速,但是真的不知道怎么弄了...请问该在哪里优化才能达到提速的效果?
我使用OpenMV4 +OV7725 测试你的代码是
FPS: 53.53319把循环里的 print("New exposure == %d" % sensor.get_exposure_us())注释掉。FPS 64
你具体想达到什么速度?
想到10ms以内,现在多几毫秒
换成全局快门,改成灰度,速度可以达到。
https://singtown.com/product/50303/global-shutter-camera-module/
请问这个速度用openmv4 H7是无法达到吗?
OpenMV4 标配的OV7725不行,需要换成MT9V034
MT9V034就是全局快门吗?
看我上面发的链接。
最新OV7725的驱动代码有更新,采集速度提高很多。但是要过一段时间,出release可以用。
怎样更新板子驱动?
过一段时间出release,直接IDE更新资源,IDE会提示更新固件。
大概什么时候能出呢?
