星瞳实验室APP,快速收到回复
  • 条形码不能通过串口发送code.payload
      sensor.set_windowing((640, 80))
      sensor.set_auto_gain(False)
      uart = UART(3,4800)
      def barcode_name(code):
      return "EAN2"
      return "EAN5"
      return "EAN8"
      return "UPCE"
      return "ISBN10"
      return "UPCA"
      return "EAN13"
      return "ISBN13"
      if(code.type() == image.I25):
      return "I25"
      return "DATABAR"
      return "DATABAR_EXP"
      return "CODABAR"
      return "CODE39"
      return "PDF417"
      return "CODE93"
      return "CODE128"
      codes = img.find_barcodes()
      for code in codes:
      img.draw_rectangle(code.rect())
      print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
      print("Barcode %s, Payload "%s", rotation %f (degrees), quality %d, FPS %f" % print_args)
      if not codes:
      print("FPS %f" % clock.fps())
      uart.write( code.payload)
      time.sleep(1000)
    • 代码格式不对,看不了
      新人先看一下 必看:玩转星瞳论坛了解一下图片上传,代码格式等问题。
