OpenMV4 plus脱机运行报错
在IDE上正常运行,脱机运行后出现了ERROR_log文件
报错内容是SDRAM failed testing!
代码如下enable_lens_corr = False # turn on for straighter lines... import sensor, image, time from pyb import UART import ujson sensor.reset() sensor.set_contrast(3) sensor.set_pixformat(sensor.GRAYSCALE) # grayscale is faster sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) clock = time.clock() uart=UART(3,9600) # All line objects have a `theta()` method to get their rotation angle in degrees. # You can filter lines based on their rotation angle. min_degree = 0 max_degree = 179 rx1_l=[] rx2_l=[] ry1_l=[] ry2_l=[] rx1_r=[] rx2_r=[] ry1_r=[] ry2_r=[] # All lines also have `x1()`, `y1()`, `x2()`, and `y2()` methods to get their end-points # and a `line()` method to get all the above as one 4 value tuple for `draw_line()`. while(True): clock.tick() img = sensor.snapshot() if enable_lens_corr: img.lens_corr(0.7) # for 2.8mm lens... # `threshold` controls how many lines in the image are found. Only lines with # edge difference magnitude sums greater than `threshold` are detected... # More about `threshold` - each pixel in the image contributes a magnitude value # to a line. The sum of all contributions is the magintude for that line. Then # when lines are merged their magnitudes are added togheter. Note that `threshold` # filters out lines with low magnitudes before merging. To see the magnitude of # un-merged lines set `theta_margin` and `rho_margin` to 0... # `theta_margin` and `rho_margin` control merging similar lines. If two lines # theta and rho value differences are less than the margins then they are merged. for l in img.find_lines(threshold = 2800, theta_margin = 35, rho_margin = 35): if (min_degree <= l.theta()) and (l.theta() <= max_degree): img.draw_line(l.line(), color = (255, 0, 0)) # print(l) #print("x1:",l.x1,"x2:",l.x2) #print(l.theta()) #k=(l.y1()-l.y2())/(l.x1()-l.x2()) if(l.x1()<125 and l.theta()<45): rx1_l.append(l.x1()) rx2_l.append(l.x2()) ry1_l.append(l.y1()) ry2_l.append(l.y2()) #print("left:",l.theta()) #print(l.x1(),l.y1(),l.x2(),l.y2()) if(l.x1()>125 and l.theta()>135): rx1_r.append(l.x1()) rx2_r.append(l.x2()) ry1_r.append(l.y1()) ry2_r.append(l.y2()) #print(l.x1(),l.y1(),l.x2(),l.y2()) if rx1_l: if rx1_r: A_1=ry2_l[-1]-ry1_l[-1] B_1=rx1_l[-1]-rx2_l[-1] C_1=rx1_l[-1]*(ry1_l[-1]-ry2_l[-1])+ry1_l[-1]*(rx2_l[-1]-rx1_l[-1]) A_2=ry2_r[-1]-ry1_r[-1] B_2=rx1_r[-1]-rx2_r[-1] C_2=rx1_r[-1]*(ry1_r[-1]-ry2_r[-1])+ry1_r[-1]*(rx2_r[-1]-rx1_r[-1]) cross_x=(B_1*C_2-B_2*C_1)/(B_2*A_1-B_1*A_2) if(cross_x>0 and cross_x<320): rcx=cross_x-125 print(cross_x-125) rxy={"rx":rcx,"ry":0} uart.write(ujson.dumps(rxy)+'\r\n') #print("FPS %f" % clock.fps()) # About negative rho values: # # A [theta+0:-rho] tuple is the same as [theta+180:+rho].
另外还有一个问题,我又两个Openmv4 plusi,出现报错的这台插入SD卡后无法被电脑识别
可以联系卖家维修。
