  • 运行圆形识别代码并同步无心啊传输数据,socket error 返回-13 什么意思,如何解决?
      import sensor, image, time, network, usocket, sys, json
      green_threshold = ( 0, 80, -70, -10, -0, 30)
      Reset sensor
      Set sensor settings
      sensor.set_contrast(3)
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      Init wlan module in AP mode.
      Init wlan module in Download mode.
      #wlan = network.WINC(mode=network.WINC.MODE_FIRMWARE)
      For ATWINC1500-MR210PB only.
      #wlan.fw_update("/winc_19_6_1.bin")
      You can block waiting for client to connect
      def response(s):
      client, addr = s.accept()
      client.settimeout(2.0)
      # Read request from client
      data = client.recv(1024)
      # Send multipart header
                  "Server: OpenMV\r\n" \
                  "Content-Type: application/json\r\n" \
                  "Pragma: no-cache\r\n\r\n")
      # FPS clock
      # Start streaming images
          for b in blobs:
      client.send(json.dumps(blobs))
      client.close()
      # Create server socket
      # Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
          # Set server socket timeout
          s.settimeout(3)
          response(s)
      except OSError as e:
          s.close()
          print("socket error: ", e)
          #sys.print_exception(e)
