[ESP32] could not find any example in Arduino framework
#include <Arduino.h> #include <SPI.h> #include <SD.h> SPIClass spiSD(VSPI); #define SD_CS 15 void setup() { Serial.begin(115200); SPI.end(); spiSD.begin(18, 19, 23, SD_CS); pinMode(39, INPUT); if (digitalRead(39) == LOW) { log_i("SDCard attached!"); } else { log_i("SDCard detached!"); } if (!SD.begin(SD_CS, spiSD)) { Serial.println("initialization failed!"); return; } } void loop() { }
https://singtown.com/learn/48770/
I try to follow this tutorial to convert the code into Arduino but I could not connect to the Sdcard.
I also change the other pin but failed toospiSD.begin(12, 13, 14, 15); //try 1 spiSD.begin(12, 13, 14, 5); //try 2
console log:
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0018,len:4 load:0x3fff001c,len:1216 ho 0 tail 12 room 4 load:0x40078000,len:9720 ho 0 tail 12 room 4 load:0x40080400,len:6352 entry 0x400806b8 [I][main.cpp:18] setup(): SDCard attached! [E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(d) initialization failed!
update 1:
I also try micro python but it not work tooimport time import machine, sdcard, os from machine import SPI, Pin ledValue = 0 led=Pin(12, Pin.OUT) led.value(1) time.sleep(1) try: sd = sdcard.SDCard(SPI(2, sck=Pin(18), mosi=Pin(23), miso=Pin(19)), Pin(15)) os.mount(sd, '/sd') ledValue = 1 except: sd = None ledValue = 0 if(sd): ledValue = 1 led.value(ledValue) #Led turn off due too sd initialize failed+
