  • [ESP32] could not find any example in Arduino framework
    • #include <Arduino.h>
      #include <SPI.h>
      #include <SD.h>
      SPIClass spiSD(VSPI);
      #define SD_CS 15
      void setup()
      	Serial.begin(115200);
      	SPI.end();
      	spiSD.begin(18, 19, 23, SD_CS);
      	pinMode(39, INPUT);
      	if (digitalRead(39) == LOW)
      		log_i("SDCard attached!");
      	else
      		log_i("SDCard detached!");
      	if (!SD.begin(SD_CS, spiSD))
      		Serial.println("initialization failed!");
      		return;
      void loop()
      https://singtown.com/learn/48770/
      I try to follow this tutorial to convert the code into Arduino but I could not connect to the Sdcard.
      I also change the other pin but failed too
      	spiSD.begin(12, 13, 14, 15); //try 1
      	spiSD.begin(12, 13, 14, 5);  //try 2
      console log:
      clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:1216
      ho 0 tail 12 room 4
      load:0x40078000,len:9720
      ho 0 tail 12 room 4
      load:0x40080400,len:6352
      entry 0x400806b8
      [I][main.cpp:18] setup(): SDCard attached!
      [E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(d)
      update 1:
      I also try micro python but it not work too
      import machine, sdcard, os
      from machine import SPI, Pin
      ledValue = 0
      led=Pin(12, Pin.OUT)
      led.value(1)
      time.sleep(1)
        sd = sdcard.SDCard(SPI(2, sck=Pin(18), mosi=Pin(23), miso=Pin(19)), Pin(15))
        os.mount(sd, '/sd')
        ledValue = 1
      except:
        sd = None
        ledValue = 0
      if(sd):
        ledValue = 1
      led.value(ledValue)  #Led turn off due too sd initialize failed+
