  • utime报错'module' object has no attribute 'sleep_ms'如何解决?
      红外RGB565跟踪示例
      这个例子展示了使用OpenMV Cam进行红外RGB565跟踪。
      import sensor, image
      #import time
      import utime
      import pyb
      thresholds = (100,100,0,0,0,0) # thresholds for bright white light from IR.
      sensor.set_windowing((240,240)) # 240x240 center pixels of VGA
      sensor.skip_frames(time = 10)
      if blob.pixels() >max_size:
      max_size = blob.pixels()
      time.sleep_ms(50)
      #clock.tick()
      #for i in range(0,600):
       # clock.tick()# Track elapsed milliseconds between snapshots().
      start = time.ticks_ms()
      #time_start = pyb.millis()
      img = sensor.snapshot()#binary([thresholds], invert=True, zero=True)
      blobs=img.find_blobs([thresholds],pixels_threshold=200,area_threshold=250)
        output_str = json.dumps(blobs)
        max_blob=find_max(blobs)
        img.draw_rectangle(max_blob.rect(),color=(255,0,0))
        output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy())
        print('you send:',output_str)
        uart.write(output_str+'\n')
        delta = time.ticks_diff(time.ticks_ms(), start)
        #duration = pyb.elapsed_millis(time_start)
        print('a',delta)
        print("FPS:", clock.fps())
              #img.draw_cross(blob.cx(), blob.cy())
                  print('not found!')
    • 改成time.sleep()
    • 在delta = time.ticks_diff(time.ticks_ms(), start)报错,'module' object has no attribute 'ticks_diff'
    • delta = utime.ticks_diff(utime.ticks_ms(), start)
