按照视频教程使用WINC 1500 WiFi扩展板,插入OpenMV,运行热点搜索和无线图传的代码时,报错。
我的也是这样,QQ群没人回复,论坛也不回复
This post is deleted!
- 首先将OpenMV ide安装目录下的wifi固件winc_19_6_1.bin保存到SD卡里 (OpenMV4 或者OpenMV4 Plus可以直接将wifi固件winc_19_6_1.bin保存在OpenMV弹出来的U盘里),(wifi固件路径: openmv-ide-install-dir OpenMV IDE安装文件夹>/share/qtcreator/firmware/WINC1500/winc_19_6_1.bin )
2.插入SD卡(OpenMV4或OpenMV4 Plus可以直接保存在OpenMV弹出来的U盘里,可不插SD卡),重新上电OpenMV
3.运行例程 14-WiFi-Shield->fw_update WINC
更新wifi固件# WINC Firmware Update Script. # # This script updates the ATWINC1500 WiFi module firmware. # 1) Copy the firmware image to a FAT32/exFAT SD card. # 2) Safe remove/eject the SD card (or umount on Linux). # 3) Reset the camera from the IDE. # 4) Run this script to update the firmware. # # NOTE: Older fimware versions are no longer supported by the host driver. # NOTE: The latest firmware (19.6.1) only works on ATWINC1500-MR210PB. # NOTE: Firmware is at <openmv-ide-install-dir>/share/qtcreator/firmware/WINC1500/winc_19_6_1.bin import network # Init wlan module in Download mode. wlan = network.WINC(mode=network.WINC.MODE_FIRMWARE) # For ATWINC1500-MR210PB only. wlan.fw_update("/winc_19_6_1.bin")
@yuan 固件比U盘内存还大,怎么存进去?
@nqow_1586691935 插内存卡
