实例WIFI-scan的时候出现了WINC模块不能用的情况![
连接连接wifi模块,使用实例WIFI-scan的时候出现了WINC模块不能用的情况
@6iyh 我这也是啊,按照视频教程做的
此回复已被删除!
- 首先将OpenMV ide安装目录下的wifi固件winc_19_6_1.bin保存到OpenMV弹出来的U盘里(wifi固件路径: openmv-ide-install-dir>/share/qtcreator/firmware/WINC1500/winc_19_6_1.bin )
2.重新上电OpenMV
3.运行例程 14-WiFi-Shield->fw_update WINC
更新wifi固件# WINC Firmware Update Script. # # This script updates the ATWINC1500 WiFi module firmware. # 1) Copy the firmware image to a FAT32/exFAT SD card. # 2) Safe remove/eject the SD card (or umount on Linux). # 3) Reset the camera from the IDE. # 4) Run this script to update the firmware. # # NOTE: Older fimware versions are no longer supported by the host driver. # NOTE: The latest firmware (19.6.1) only works on ATWINC1500-MR210PB. # NOTE: Firmware is at <openmv-ide-install-dir>/share/qtcreator/firmware/WINC1500/winc_19_6_1.bin import network # Init wlan module in Download mode. wlan = network.WINC(mode=network.WINC.MODE_FIRMWARE) # For ATWINC1500-MR210PB only. wlan.fw_update("/winc_19_6_1.bin")
@yuan 这个文件都比弹出来这个U盘还大,根本放不进去
@6iyh 对啊,应该怎么办?
需要插入SD卡。
