  • 接了一个AMG8833的模块,使用官网的例程,没报错但是获取的数值都是0
    • # AMG8833 Overlay Demo
      # This example shows off how to overlay a heatmap onto your OpenMV Cam's
      # live video output from the main camera.
      import sensor, image, time, fir
      ALT_OVERLAY = False # Set to True to allocate a second ir image.
      # Initialize the thermal sensor
      fir.init(type=fir.FIR_AMG8833)
      # Allocate another frame buffer for smoother video.
      extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.RGB565)
      # FPS clock
          # Capture an image
          # Capture FIR data
          #   ta: Ambient temperature
          #   ir: Object temperatures (IR array)
          #   to_min: Minimum object temperature
          #   to_max: Maximum object temperature
          ta, ir, to_min, to_max = fir.read_ir()
          if not ALT_OVERLAY:
              # Scale the image and belnd it with the framebuffer
              fir.draw_ir(img, ir)
              # Create a secondary image and then blend into the frame buffer.
              extra_fb.clear()
              fir.draw_ir(extra_fb, ir, alpha=256)
              img.blend(extra_fb, alpha=128)
          # Draw ambient, min and max temperatures.
          img.draw_string(8, 0, "Ta: %0.2f C" % ta, color = (255, 0, 0), mono_space = False)
          img.draw_string(8, 8, "To min: %0.2f C" % to_min, color = (255, 0, 0), mono_space = False)
          img.draw_string(8, 16, "To max: %0.2f C"% to_max, color = (255, 0, 0), mono_space = False)
          # Force high quality streaming...
          img.compress(quality=90)
          # Print FPS.
