  • 想问一下,进行颜色识别后再将RGB565转为灰度图,但是之后的模板匹配没现象?
      thresholds = [(16, 50, 24, 99, -18, 67),
                    (40, 65, -32, 32, 27, 82),
                    (10, 27, -52, -16, -19, 99)]
      #templates = ["/left.pgm", "/right.pgm", "/band.pgm"] #保存多个模板
      template1 = image.Image("left.pgm")
      template2 = image.Image("right.pgm")
      template3 = image.Image("band.pgm")
          for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
              if blob.code() == 1:
                 print("前方为红灯")
              if blob.code() == 2:
                 print("前方为黄灯")
              if blob.code() == 4:
                 print("前方为绿灯")
              if blob.code()!=1 and blob.code()!=2 and blob.code()!=4:
                  img = img.to_grayscale()
                  r = img.find_template(template1, 0.10, step=4, search=SEARCH_EX) #, roi=(81, 49, 165, 166))
                  if r:
                      img.draw_rectangle(r)
                      print("前方左转")
                  r = img.find_template(template2, 0.10, step=4, search=SEARCH_EX) #, roi=(81, 49, 165, 166))
                  if r:
                      print("前方右转")
                  r = img.find_template(template3, 0.10, step=4, search=SEARCH_EX) #, roi=(81, 49, 165, 166))
                  if r:
                      print("禁止通行")
    • https://singtown.com/learn/49598/
      单独模板匹配的代码,是正常的吗?
