对比度比较低识别率大幅下降怎么办?
import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) # grayscale is faster sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) clock = time.clock() while(True): clock.tick() img = sensor.snapshot().lens_corr(1.2) # Circle objects have four values: x, y, r (radius), and magnitude. The # magnitude is the strength of the detection of the circle. Higher is # better... # `threshold` controls how many circles are found. Increase its value # to decrease the number of circles detected... # `x_margin`, `y_margin`, and `r_margin` control the merging of similar # circles in the x, y, and r (radius) directions. # r_min, r_max, and r_step control what radiuses of circles are tested. # Shrinking the number of tested circle radiuses yields a big performance boost. for c in img.find_circles(threshold = 3500, x_margin = 15, y_margin = 15, r_margin = 15, r_min = 2, r_max = 100, r_step = 2): img.draw_circle(c.x(), c.y(), c.r()+2, color = (255, 0, 0)) print(c) print("FPS %f" % clock.fps())
加一个灯,用于照明。
