  • lcd连接数据线的时候能正常显示,外接电源之后中间有一半白屏是怎么回事
    • 需要提供代码,和照片。
    • THRESHOLD = (51, 100, 0, 21, 12, 33) #线路阈值
      import sensor, image, time,lcd
      from pyb import Servo
      rho_pid = PID(p=0.4, i=0) #截距
      theta_pid = PID(p=0.001, i=0) #斜率
      s1 = Servo(3) # P9
      def run(_angle,_range,_sleep): #角度,幅度,间隔延时
      s1.angle(_angle+_range) #角度,转到该角度的时间
      time.sleep(_sleep)
      s1.angle(_angle-_range)
      time.sleep(_sleep)
      sensor.set_framesize(sensor.QQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000.
      clock = time.clock() # to process a frame sometimes.
      lcd.init()
      #img = sensor.snapshot()
      if (line):
      if line.theta()>90:
      theta_err = line.theta()-180
      print(rho_err,line.magnitude(),theta_err)
          #lcd.display(sensor.snapshot())
          lcd.display(img.draw_line(line.line(),color=127))
          if line.magnitude()>0:
              #output=output*3
              if theta_err>70:        #限制摆动角度
                  theta_err=70
              if theta_err<-70:
                  theta_err=-70
              run(theta_err,15,180)     #角度,幅度,间隔延时
          pass![0_1572269044774_852B78E315A605550E330DB196766244.jpg](https://fcdn.singtown.com/0c8ae143-f07e-48e3-99e2-85338bb96b25.jpg)
    • https://singtown.com/learn/49601/
      用例子进行测试。
