  • openmv与stm32f103rct6数据格式接受问题,电脑串口助手显示单片机接受一堆非二进制数?
    • 请在这里粘贴代码
      ```# Blob Detection and uart transport
      red_threshold=(18, 69, 40, 86, 0, 72)
      uart = UART(3, 19200)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
              max_blob=find_max(blobs)
              #print('sum :', len(blobs))
              output_str="%d%d" % (max_blob.cx(),max_blob.cy()) #方式1
              print('',output_str)
              uart.write(output_str+'\r\n')
      单片机程序
      #include "stm32f10x.h"
      #include "./led/bsp_led.h"
      #include "./uart/bsp_uart.h"
      void delay(uint32_t count)
      	for(; count!=0; count--);
      int main(void)
      	uint8_t temp;
      	LED_GPIO_Config();
      	DEBUG_UART_Config();
      	while(1)
      		temp = getchar();
      		printf("%d%d\n",temp);
      			if (temp=(75,73))
      			{LED1_ON;
      			  LED2_OFF;}
      			else if (temp=(75,46))
      			{LED2_ON;
      			  LED1_OFF;}
      			else;
      				{LED2_OFF
      			  LED1_OFF;}
      串口助手接收数据如下:[16:46:56.953]收←◆541073821696
      511073821696
      [16:46:56.988]收←◆541073821696
      501073821696
      [16:46:57.024]收←◆541073821696
      501073821696
      [16:46:57.059]收←◆541073821696
      501073821696
      [16:46:57.094]收←◆541073821696
      501073821696
      [16:46:57.129]收←◆541073821696
      501073821696
      [16:46:57.164]收←◆541073821696
      501073821696
      [16:46:57.200]收←◆541073821696
      501073821696
      [16:46:57.235]收←◆541073821696
      501073821696
      [16:46:57.271]收←◆541073821696
      501073821696
      openmv发送数据如下:
      6248
       6248
       6249
       6249
       6249
       6249
       6250
       6250
       6250
      数据格式不统一,不知道如何解决
    • https://singtown.com/learn/50235/
      发送的是字符串。看视频操作。
    • @phs4 楼主你调试成功了吗?
