我要识别一个方块,但是背景是复杂变换的,特征点检测是不是不好用?
import sensor, time, image,pyb
led=pyb.LED(2)Reset sensor
Sensor settings
sensor.set_contrast(3)
sensor.set_windowing((160, 120))
kpts=["/0.orb","1.orb","2.orb","3.orb"]
#kpts1 = image.load_descriptor("/desc.orb")clock = time.clock()
if (kpts2):
for t in kpts:
kpts=image.load_descriptor(t)
match = image.match_descriptor(kpts, kpts2, threshold=85)
if (match.count()>10):
led.on()
# 匹配度大于10
led.off()print(kpts2, "matched:%d dt:%d"%(match.count(), match.theta())) img.draw_string(0, 0, "FPS:%.2f"%(clock.fps()))
请提供你的图片。
