大佬,请问openm m4在巡线小车里面
THRESHOLD = (5, 70, -23, 15, -57, 0) # Grayscale threshold for dark things...
from pyb import LED
import car
rho_pid = PID(p=0.4, i=0)
theta_pid = PID(p=0.001, i=0)LED(1).on()
LED(2).on()
LED(3).on()sensor.reset()
sensor.set_vflip(True)
sensor.set_hmirror(True)
clock = time.clock() # to process a frame sometimes.while(True):
if (line):
if line.theta()>90:
theta_err = line.theta()-180
if line.magnitude()>8:
car.run(50+output, 50-output)
car.run(0,0)
car.run(50,-50)
pass
#print(clock.fps())
openmv m4 中的sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000.能够换成分辨率为320*240吗,我说的是彩色图像
可以,你试试就知道了。QVGA。
