  • 这个是什么错误呢???
    • TypeError: unsupported types for lt: 'int', 'bound_method'0_1566785846299_1.png
    • 这个是全部代码了,我只是想在矩形识别的基础上进行像素统计,进行颜色识别
      sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
      # `threshold` below should be set to a high enough value to filter out noise
      # rectangles detected in the image which have low edge magnitudes. Rectangles
      # have larger edge magnitudes the larger and more contrasty they are...
      blos= img.find_rects(threshold = 12000)
      if blos:
        print('sum')
        for r in blos:
            area=(r.x(),r.y(),r.w(),r.h())
            statistics=img.get_statistics(roi=area)
            if 0<statistics.l_mode<127 and 0<statistics.a_mode<127 and 0<statistics.b_mode<127:
                print(r)
                uart.write('red')
    • 函数或者方法的话,需要用括号调用。
    • statistics.l_mode()
    • This post is deleted!
    • @dx1i 不同的问题,单独发帖子。
