  • 类型错误;无法将int转换为类型
      ![0_1566119359388_屏幕截g](https://fcdn.singtown.com/1eb90841-fe8d-4f87-b93d-515d9cb2
      4640.png)
      # Template Matching Example - Normalized Cross Correlation (NCC)
      # NCC is not all to useful.
      import time, sensor, image
      # Reset sensor
      # Set sensor settings
      # Load template.
      template = image.Image("/1.pgm")
      # Run template matching
          r = img.find_template(1, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r:
              img.draw_rectangle(r)
    • 代码不对,按照视频步骤操作。
      https://singtown.com/learn/49598/
      你那个1,不对。
