  • 为什么红色和圆形识别都无法实现?
      import math
      from pyb import UART #通过pyb模块引入UART类
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      red_threshold =(60, 70, 40, 75, 30, 50) #(60,65,40,60,40,45)
      pan_pid = PID(p=0.2 , i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      tilt_pid = PID(p=0.18, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID
      #sensor.set_vflip(F)
      sensor.set_auto_gain(True) #关闭自动亮度增益,太暗了可以自行打开
      uart = UART(3, 115200)#设置波特率,串口号
      #确定最大球
      K=1250 #测距参数,在2.5m附近较准确
      blobs = img.find_circles(threshold = 3000, x_margin = 10, y_margin = 10, r_margin = 20,r_min = 5, r_max = 100, r_step = 2)
      #寻块,舵机转动
      #if blobs == 1:测距部分
      b = blobs[0]
      #img.draw_cross(b[5], b[6]) # cx, cy
      Lm = (b[2]+b[3])/2
      length = K/Lm
      print("length:",length)
      #检测点的坐标
      data2=[]
      for b in blobs:
      # img.draw_rectangle(b.rect())
      # img.draw_cross(b.cx(), b.cy())
      data2.append((b.cx(),b.cy()))
      x = str(max_blob.cx())
      y = str(max_blob.cy())
      for a in range(2):
      if (len(x)!=3):
      x='0'+x
      for b in range(2):
      if (len(y)!=3):
      y='0'+y
      uart.write('x'+x+'y'+y+'\r\n')
      print('x'+x+'y'+y+'\n') #得到x,y坐标
      tan=abs(max_blob.cx()-80)/length #利用dx和测得的距离求出直角三角形的tan
      a=math.atan(tan)*57.325 #反三角函数得角度
              print("arctan=",a)
              print("not found!")
      错误提示
      File "", line 41, in
      Exception: IDE interrupt
      MicroPython v1.9.4-4548-g24c934f79 on 2019-03-23; OPENMV4 with STM32H743
      Type "help()" for more information.
