  • 如何利用NRF24L01实现OPENMV4与主控STM32F1系列单片机的无线通信?
    • -- coding: UTF-8 --
      import RPi.GPIO as GPIO
      #一下试一下nrf24l01的C语言宏定义
      TX_ADR_WIDTH = 5 # 5 uints TX address width
      RX_ADR_WIDTH = 5 # 5 uints RX address width
      TX_PLOAD_WIDTH = 32 # 20 uints TX payload
      RX_PLOAD_WIDTH = 32 # 20 uints TX payload
      TX_ADDRESS = [0x34,0x43,0x10,0x10,0x01] #本地地址
      RX_ADDRESS = [0x34,0x43,0x10,0x10,0x01] #接收地址
      READ_REG = 0x00 # 读寄存器指令
      WRITE_REG = 0x20 # 写寄存器指令
      RD_RX_PLOAD = 0x61 # 读取接收数据指令
      WR_TX_PLOAD = 0xA0 # 写待发数据指令
      FLUSH_TX = 0xE1 # 冲洗发送 FIFO指令
      FLUSH_RX = 0xE2 # 冲洗接收 FIFO指令
      REUSE_TX_PL = 0xE3 # 定义重复装载数据指令
      NOP = 0xFF # 保留
      #SPI(nRF24L01)寄存器地址***************
      CONFIG = 0x00 # 配置收发状态,CRC校验模式以及收发状态响应方式
      EN_AA = 0x01 # 自动应答功能设置
      EN_RXADDR = 0x02 # 可用信道设置
      SETUP_AW = 0x03 # 收发地址宽度设置
      SETUP_RETR = 0x04 # 自动重发功能设置
      RF_CH = 0x05 # 工作频率设置
      RF_SETUP = 0x06 # 发射速率、功耗功能设置
      STATUS = 0x07 # 状态寄存器
      OBSERVE_TX = 0x08 # 发送监测功能
      CD = 0x09 # 地址检测
      RX_ADDR_P0 = 0x0A # 频道0接收数据地址
      RX_ADDR_P1 = 0x0B # 频道1接收数据地址
      RX_ADDR_P2 = 0x0C # 频道2接收数据地址
      RX_ADDR_P3 = 0x0D # 频道3接收数据地址
      RX_ADDR_P4 = 0x0E # 频道4接收数据地址
      RX_ADDR_P5 = 0x0F # 频道5接收数据地址
      TX_ADDR = 0x10 # 发送地址寄存器
      RX_PW_P0 = 0x11 # 接收频道0接收数据长度
      RX_PW_P1 = 0x12 # 接收频道0接收数据长度
      RX_PW_P2 = 0x13 # 接收频道0接收数据长度
      RX_PW_P3 = 0x14 # 接收频道0接收数据长度
      RX_PW_P4 = 0x15 # 接收频道0接收数据长度
      RX_PW_P5 = 0x16 # 接收频道0接收数据长度
      FIFO_STATUS = 0x17 # FIFO栈入栈出状态寄存器设置
      TX_OK = 0x20 #TX发送完成中断
      MAX_TX = 0x10 #达到最大发送次数中断
      #sta = 0
      #RX_DR = 0
      #树莓派各个引脚的定义
      MOSI = 29
      CSN = 31
      MISO = 33
      SCK = 35
      CE = 37
      IRQ = 32
      def GPIO_Init():
      GPIO.setmode(GPIO.BOARD)
      GPIO.setwarnings(False)
      Pinlist = [29,31,35,37,11]
      GPIO.setup(Pinlist, GPIO.OUT)
      Pinlist_Input = [33,32]
      GPIO.setup(Pinlist_Input, GPIO.IN)
      return 0
      def LEDH():
      GPIO.output(11, GPIO.HIGH)
      def LEDL():
      GPIO.output(11, GPIO.LOW)
      #函数:uint SPI_RW(uint dat)
      #功能:NRF24L01的SPI写时序
      def SPI_RW(dat):
      bit_ctr = 8
      _MOSI = 0
      while(bit_ctr):
          bit_ctr = bit_ctr - 1
          _MOSI = dat & 0x80              #output 'dat', MSB to MOSI
          if(_MOSI):
              GPIO.output(MOSI, GPIO.HIGH)
              GPIO.output(MOSI, GPIO.LOW)
          dat = (dat << 1)                #shift next bit into MSB..
          GPIO.output(SCK, GPIO.HIGH)          #Set SCK GPIO.high..
          dat |= GPIO.input(MISO)        #capture current MISO bit
          GPIO.output(SCK, GPIO.LOW)           #..then set SCK GPIO.low again
      return dat           		        #return read dat
      #函数:uchar SPI_Read(uchar reg)
      #功能:NRF24L01的SPI读时序
      def SPI_Read(reg):
      reg_val = 0
      GPIO.output(CSN, GPIO.LOW) #CSN GPIO.low, initialize SPI communication...
      SPI_RW(reg) #Select register to read from..
      reg_val = SPI_RW(0) #..then read registervalue
      GPIO.output(CSN, GPIO.HIGH) #CSN GPIO.high, terminate SPI communication
      return reg_val #return register value
      #功能:NRF24L01读写寄存器函数
      def SPI_RW_Reg(reg,value):
      status = 0
      GPIO.output(CSN, GPIO.LOW) #CSN GPIO.low, init SPI transaction
      status = SPI_RW(reg) #select register
      SPI_RW(value) #..and write value to it..
      GPIO.output(CSN, GPIO.HIGH) #CSN GPIO.high again
      return status #return nRF24L01 status uchar
      #函数:uint SPI_Read_Buf(uchar reg, uchar pBuf, uchar uchars)
      #功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数
      def SPI_Read_Buf(reg, pBuf, uchars):
      status = 0
      uchar_ctr = 0
      GPIO.output(CSN, GPIO.LOW) # Set CSN GPIO.low, init SPI tranaction
      status = SPI_RW(reg) # Select register to write to and read status uchar
      while(uchar_ctr < uchars):
      pBuf[uchar_ctr] = SPI_RW(0) #
      uchar_ctr = uchar_ctr + 1
      return(status) #return nRF24L01 status uchar
      #函数:uint SPI_Write_Buf(uchar reg, uchar pBuf, uchar uchars)
      #功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数
      def SPI_Write_Buf(reg, pBuf, uchars):
      status = 0
      uchar_ctr = 0
      GPIO.output(CSN, GPIO.LOW) #SPI使能
      while(uchar_ctr < uchars): #
      SPI_RW(pBuf[uchar_ctr])
      GPIO.output(CSN, GPIO.HIGH) #关闭SPI
      return(status)
      #函数:void SetRX_Mode(void)
      #功能:数据接收配置
      def SetRX_Mode():
      GPIO.output(CE, GPIO.LOW)
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f) # IRQ收发完成中断响应,16位CRC ,主接收
      GPIO.output(CE, GPIO.HIGH)
      #函数:unsigned char nRF24L01_RxPacket(unsigned char rx_buf)
      #功能:数据读取后放如rx_buf接收缓冲区中
      def nRF24L01_RxPacket(rx_buf):
      revale = 0
      sta = 0
      RX_DR = 0
      sta = SPI_Read(STATUS)	                                # 读取状态寄存其来判断数据接收状况
      RX_DR = sta&0x40
      if(RX_DR):				                                # 判断是否接收到数据
          GPIO.output(CE, GPIO.LOW) 			                #SPI使能
          SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH)     # read receive payload from RX_FIFO buffer
          revale =1			                                #读取数据完成标志
      SPI_RW_Reg(WRITE_REG+STATUS,sta)                        #接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
      return revale
      #函数:void nRF24L01_TxPacket(unsigned char * tx_buf)
      #功能:发送 tx_buf中数据
      def nRF24L01_TxPacket(tx_buf):
      sta = 0
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e)
      time.sleep(0.00001)
      GPIO.output(CE, GPIO.LOW) #StandBy I模式
      SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH) # 装载数据
      GPIO.output(CE, GPIO.HIGH) #置高CE,激发数据发送
      # while(GPIO.input(IRQ)!=0) #等待发送完成
      sta=SPI_Read(STATUS)
      if(sta & MAX_TX): #达到最大重发次数
      SPI_RW_Reg(FLUSH_TX,0xff) #清除TX FIFO寄存器
      return MAX_TX
      if(sta&TX_OK):                                              #发送完成
          return 0
      return 0xff                                                 #其他原因发送失败
      #NRF24L01初始化
      def Init_NRF24L01():
      GPIO.output(CE, GPIO.LOW) # chip enable
      GPIO.output(CSN, GPIO.HIGH) # Spi disable
      GPIO.output(SCK, GPIO.LOW) # Spi clock line init GPIO.high
      SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH) # 写本地地址
      SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH) # 写接收端地址
      SPI_RW_Reg(WRITE_REG + EN_AA, 0x01) # 频道0自动 ACK应答允许
      SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01) # 允许接收地址只有频道0,如果需要多频道可以参考Page21
      SPI_RW_Reg(WRITE_REG + RF_CH, 40) # 设置信道工作为2.4GHZ,收发必须一致
      SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH) #设置接收数据长度,本次设置为32字节
      SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f) #设置发射速率为1MHZ,发射功率为最大值0dB
      return 0
      if name == "main":
      TxBuf = [1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0]
      RxBuf = [0,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0,1,0,0,0]
      GPIO_Init()
      Init_NRF24L01()
      SetRX_Mode()
      if nRF24L01_RxPacket(RxBuf):
      if RxBuf[0]:
      print(RxBuf)
      LEDH()
      SetRX_Mode()
      time.sleep(1)
      LEDL()
      time.sleep(1)
      这套PYTHON的NRF24L01程序可以用在OPENMV上么?
      这是树莓派的一套程序。
    • 不行,openmv没有这个库文件
    • 那怎么实现通过nrf让openMV无线通信嘞,还是只能用它配套的无线WiFi模块?
    • 你可以用串口的无线模块,很简单。
    • nrf24l01处理起来很麻烦,所以一直没有完成这个库。
