  • 关于OpenMV文件写入的问题
          f = open("test.txt")
          for tag in img.find_apriltags(families=tag_families): # defaults to TAG36H11 without "families".
              print_args = (family_name(tag), tag.id(), (180 * tag.rotation()) / math.pi)
              id = tag.id()
              f.write(id)
    • 请提供全部的代码,否则我没办法测试。
      import sensor, image, time, math, pyb
      tag_families = 0
      tag_families |= image.TAG16H5 # comment out to disable this family
      tag_families |= image.TAG25H7 # comment out to disable this family
      tag_families |= image.TAG25H9 # comment out to disable this family
      tag_families |= image.TAG36H10 # comment out to disable this family
      tag_families |= image.TAG36H11 # comment out to disable this family (default family)
      tag_families |= image.ARTOOLKIT # comment out to disable this family
      def family_name(tag):
          if(tag.family() == image.TAG16H5):
              return "TAG16H5"
          if(tag.family() == image.TAG25H7):
              return "TAG25H7"
          if(tag.family() == image.TAG25H9):
              return "TAG25H9"
          if(tag.family() == image.TAG36H10):
              return "TAG36H10"
          if(tag.family() == image.TAG36H11):
              return "TAG36H11"
          if(tag.family() == image.ARTOOLKIT):
              return "ARTOOLKIT"
              #print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
              id = tag.id()
              f.write(id)
          #print(clock.fps())
    • @kidswong999 麻烦了
    • 需要把id从数字变为字符串,然后写入文件。
      f.write(str(id))
      PS:你这个代码。。。只open,不close啊。
    • @kidswong999 谢提醒,close了😂 但改为写入字符串就又出现了了不知名错误……0_1564662247648_56b8ffa5-e4a9-46f3-81c9-9b9150b560fa-image.png
    • @kidswong999 感谢
