  • 怎么给arduino传16进制的数字1,2,3,4,5,,,,
    • # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      yellow_threshold   = (27, 61, 36, 127, -128, 127)
      uart = UART(3, 9600)
      K=640#the value should be measured
          if len(blobs) == 1:
              b = blobs[0]
              if 0<b[5]<160/3 and 0<b[6]<40:
                  uart.write('0x01')
                  #print(b[5],b[6])
              if b[5]<320/3 and b[6]<40:
                  uart.write('2')
                  #print(b[5],b[6])
              if 320/3<b[5]<160 and 0<b[6]<40:
                  uart.write('3')
                  #print(b[5],b[6])
              if 0<b[5]<160/3 and 40<b[6]<80:
                  uart.write('4')
                  #print(b[5],b[6])
              if 160/3<b[5]<320/3 and 40<b[6]<80:
                  uart.write('5')
                  #print(b[5],b[6])
              if 320/3<b[5]<160 and 40<b[6]<80:
                  uart.write('6')
                  #print(b[5],b[6])
              if 0<b[5]<160/3 and 80<b[6]<120:
                  uart.write('7')
                  #print(b[5],b[6])
              if 160/3<b[5]<320/3 and 80<b[6]<120:
                  uart.write('8')
                  #print(b[5],b[6])
              if 320/3<b[5]<160 and 80<b[6]<120:
                  uart.write('9')
                  #print(b[5],b[6])
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
    • uart.write(bytes([1]))
      uart.write(bytes([2]))
      uart.write(bytes([3]))
      uart.write(bytes([4]))
      uart.write(bytes([5]))
