关于追小球的云台例程的问题
在追小球的云台这一例程里,我加了一个旋转摄像头的函数,舵机的控制就变成反着旋转,请问应该怎么修改?
import sensor, image, time from pid import PID from pyb import Servo pan_servo=Servo(1) tilt_servo=Servo(2) orange_threshold = (52, 75, 9, 127, 32, 95) pan_pid = PID(p=0.07, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID tilt_pid = PID(p=0.05, i=0, imax=90) #脱机运行或者禁用图像传输,使用这个PID #pan_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID #tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PID sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(10) sensor.set_auto_whitebal(False) sensor.set_vflip(True) clock = time.clock() def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([orange_threshold]) if blobs: max_blob = find_max(blobs) #寻找最大色块 pan_error = max_blob.cx()-img.width()/2 #左右偏差=色块中心x-色块宽度/2 tilt_error = max_blob.cy()-img.height()/2 #上下偏差=色块中心y-色块长度/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) #画矩形 img.draw_cross(max_blob.cx(), max_blob.cy()) #色块中心画十字 pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output)
旋转摄像头的函数为sensor.set_vflip(True)
@kidswong999 多谢,问题已解决,前面加sensor.set_hmirror(True)和sensor.set_vflip(True),然后 将 pan_error 和 tilt_error 算出来的值加个负号就行了
