为什么我通过串口匿名发送的数据,有一个数据位一直为0
Blob Detection and uart transport
import sensor, image, time,math
import jsonFor color tracking to work really well you should ideally be in a very, very,
yellow_threshold = (75, 63, -55, 37, -55, -1)
clock = time.clock() # Tracks FPS.uart = UART(3, 115200)
uart.init(115200, bits=8, parity=None, stop=1) #8位数据位,无校验位,1位停止位、
if blob.pixels() > max_size:
max_blob = blob
max_size = blob.pixels()
return max_blobwhile(True):
img = sensor.snapshot() # Take a picture and return the image.blobs = img.find_blobs([yellow_threshold]) if blobs: max_blob=find_max(blobs) print('sum :', len(blobs)) img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) x1 = hex(max_blob.cx()) y1 = hex(max_blob.cy()) x2 = max_blob.cx() y2 = max_blob.cy() jiaoyan=0xaa+0x05+0xaf+0xf1+0x02+y2+x2 #output_str=json.dumps([max_blob.cx(),max_blob.cy()]) #方式2![0_1563516584463_`$WYLQN}450~SUHYRXF@P8E.png](https://fcdn.singtown.com/976132a1-b197-41bd-b063-3b995573e719.png) data = bytearray([0xaa,0x05,0xaf,0xf1,0x02,x2,y2,jiaoyan]) uart.write(data) print('you send:',x1,y1,x2,y2)
你应该print(data)来检查。
