  • 报错出现MemoryError:。。请问是什么问题呢?
    • 下面的代码报错:MemoryError: Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue!
      # 颜色二值化滤波例子
      # 这个脚本展示了二值图像滤波。
      # 您可以传递二进制任意的阈值来分割图像。
      #如果是灰度图,则只需设置(min, max)两个数字即可。
      red_threshold = (25, 95, 77, 22, -16, 63) # L A B
      green_threshold = (0,100,   -128,0,   0,127) # L A B
      blue_threshold = (0,100,   -128,127,   -128,0) # L A B
              img.binary([red_threshold])
              rects = img.find_rects(threshold = 40000)
              circles = img.find_circles(threshold = 5500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 5, r_max = 100, r_step = 2)
              blobs = img.find_blobs([black],area_threshold=50, pixels_threshold=50)
              if rects:
                  for r in rects:
                      print("find rects")
                  continue
              if circles:
                  for c in circles:
                      print("find circles")
                  continue
                  max_blob=find_max(blobs)
                  img.draw_cross(max_blob.cx(),max_blob.cy())
                  k = max_blob.pixels() / max_blob.area()
                  if(k <= 0.6):
                      print("find sanjiao")
                  continue
    • 使用QQVGA替代QVGA。
    • 嗯嗯 ,解决啦,谢谢
    • @kidswong999 改了之后还是报错,怎么办呢?
    • @vze3 发新的帖子,附上全部的代码和使用的硬件型号等信息。
