  • 我出现这个问题,请问这要怎么解决?
      代码如下:
      THRESHOLD = (5, 70, -23, 15, -57, 0) # Grayscale threshold for dark things...
      from pyb import LED
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      LED(1).on()
      LED(2).on()
      LED(3).on()
      #sensor.set_vflip(True)
      #sensor.set_hmirror(True)
      clock = time.clock()  # to process a frame sometimes.
          if (line):
              if line.theta()>90:
                  theta_err = line.theta()-180
              if line.magnitude()>8:
                 # output_str="[%d,%d]" % (50+output,50-outpu)
                  uart.write(output)
                  #car.run(50+output, 50-output)
                  #output_str="[%d,%d]" % (0,0)
                  uart.write("100")
                  #car.run(0,0)
              #output_str="[%d,%d]" % (50,-50)
              uart.write("99")
              #car.run(50,-50)
              pass
          #print(clock.fps())
