  • 为什么用串口助手接受 不到呢?
    • # Untitled - By: HP - 周五 6月 7 2019
      import sensor,time,pyb,math,image
      from pyb import Pin,Timer,LED,UART
      uart_buf =bytearray([0x55,0x00,0x00,0x00,0x00,0xAA])
      #设置发送串口3
      uart = UART(3,9600)
      uart.init(9600,bits=8,parity=None,stop=1)
      x_error =0
      y_error =0
      x_Sign = 0
      y_Sign = 0
      error_flag=0
      car_lost=1
      lenth=3
      def find_max(blobs):    #寻找最大色块函数定义
          max_pixels=0         #通过像素比较
          for blob in blobs:     #blob[0,1,2,3,4]=x,y,w,h,pixels (int)
               if blob[4]>max_pixels:
                   max_pixels=blob[4]
      sensor.set_framesize(sensor.QQVGA) # we run out of memory if the resolution is much bigger...  图像像素大小QQVGA是160✖120
      sensor.skip_frames(30)
      sensor.set_auto_exposure(True)
      black = (25, 95, 77, 22, -16, 63)
         img=sensor.snapshot()
         blobs = img.find_blobs([black])
            max_blob=find_max(blobs)
            img.draw_cross(max_blob.cx(),max_blob.cy())
            x_error = int(max_blob.cx()-img.width()/2)
            y_error = int(max_blob.cy()-img.height()/2)
            if x_error==0:
               x_Sign = 0
            if x_error >0:
               x_Sign = 1
            if x_error <0:
               x_Sign = 2
            if y_error == 0:
               y_Sign = 0
            if y_error >0:
               y_Sign = 1
            if y_error < 0:
               y_Sign = 2
            error_flag=0
            print_data=(error_flag,x_error,y_error)
            print('error_flag: %d x_error: %d y_error: %d' % print_data)
            #x_abs=abs(x_error)
            #y_abs=abs(y_error)
            uart_buf_1 = bytearray([0x55, lenth, error_flag, x_error, y_error, 0xAA])
            uart.write(uart_buf_1)
            error_flag |= car_lost
            x_error = 0
            y_error = 0
            uart_buf_2 = bytearray([0x55, lenth, error_flag, x_error, y_error, 0xAA])
            uart.write(uart_buf_2)
    • https://singtown.com/learn/50235/
      先按照视频操作。
