  • 舵机转动后摄像头帧率会掉到很低,怎么办?
      from pyb import Servo
      pan_servo=Servo(1)# P7
          for i in range(-45,45):
              pan_servo.angle(i)
              time.sleep(20)
              print('servo.angle():',pan_servo.angle())
          for i in range(45,-45,-1):
              pan_servo.angle(i)
              time.sleep(20)
          print('fps:',clock.fps())
    • 你的代码里有time.sleep,所以帧率低。
      解决办法:删除time.sleep
