from pyb import CAN 报错?
同一串代码,在OpenMV3 R2里面运行正常(如图1),在OpenMV4 H7里面运行出现错误(如图2)
import sensor, image, time from pyb import CAN sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. while(True): clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected # to the IDE. The FPS should increase once disconnected.
CAN总线在OpenMV4没启用。估计下一次固件解决。
@kidswong999 OK,专门买最新一代V4来用的
,下一代固件赶紧启用CAN总线啊,要不然我毕不了业了
@qrz4 CAN总线目前没有教程,而且CAN扩展板没有出售。
@kidswong999 OpenMV3里面CAN总线测试成功了,用的CAN收发器,买了个OpenMV4想提高一下画质和处理速度,结果没启用CAN总线,相对于白买的OpenMV4咯?
你可以等过一阵的新版本。
