roi 无效是什么意思
import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() while(True): clock.tick() img = sensor.snapshot() for r in img.find_rects(threshold = 2000): area =r.rect() #(r.x(),r.y(),r.w(),r.h()) L = (r[2]+r[3])/2 l=int(1000/L) statistics = img.get_statistics(roi=area)#像素颜色统计 if 38<statistics.l_mode()<55 and 34<statistics.a_mode()<68 and -15<statistics.b_mode()<55:#if the circle is red img.draw_rectangle(area, color = (255, 0, 0)) print("FPS %f" % clock.fps())
报错的关键字是:OSError: Invalid roi dimensions
程序有时候运行没问题 有时候运行着就报这个错
你print(area)看一下出错的时候的值。
