如何在寻线的时候把识别过程录制下来
在做寻线小车时候,想把识别直线的过程录制下来,方便调参数,应该怎么添加录像。
# Image Writer Example # # USE THIS EXAMPLE WITH A USD CARD! Reset the camera after recording to see the file. # # This example shows how to use the Image Writer object to record snapshots of what your # OpenMV Cam sees for later analysis using the Image Reader object. Images written to disk # by the Image Writer object are stored in a simple file format readable by your OpenMV Cam. THRESHOLD = (0, 35, -16, 13, -15, 23) import sensor, image, pyb, time from pyb import UART record_time = 10000 # 10 seconds in milliseconds sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) sensor.skip_frames(time = 2000) clock = time.clock() uart = UART(3, 9600) img_writer = image.ImageWriter("/stream.bin") # Red LED on means we are capturing frames. red_led = pyb.LED(1) red_led.off() start = pyb.millis() while pyb.elapsed_millis(start) < record_time: clock.tick() #img = sensor.snapshot() # Modify the image if you feel like here... img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True) if (line): img.draw_line(line.line(), color = 127) if line.theta()>90: theta_err = 270 - line.theta() else: theta_err = 90 - line.theta() #print(line.magnitude(),line.theta(),line.rho()) img_data = bytearray([theta_err]) uart.write(img_data+'\r\n') #led3.on() print(theta_err,line.theta()) #print(clock.fps()) img_writer.add_frame(img) print(clock.fps()) img_writer.close() # Blue LED on means we are done. red_led.off() blue_led = pyb.LED(3) blue_led.on() #blue_led.off() print("Done") while(True): clock.tick() #img = sensor.snapshot() # Modify the image if you feel like here... img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True) if (line): img.draw_line(line.line(), color = 127) if line.theta()>90: theta_err = 270 - line.theta() else: theta_err = 90 - line.theta() #print(line.magnitude(),line.theta(),line.rho()) img_data = bytearray([theta_err]) uart.write(img_data+'\r\n') #led3.on() print(theta_err,line.theta())
此回复已被删除!
你代码的问题是什么?
录制下来的视频不能播放
你的代码不对,请运行我链接里面的代码。
您的代码里面只有录制视频,想要实现的功能是寻线的同时还要录制视频,在我播放这段视频的时候应该出现巡线的过程,视频中有巡线时出现的边框啊之类的一些东西,请问可以实现吗?谢谢。
