  • 找不到目标就报错,找的到目标就可以正常运行???
      yellow_threshold   = (79, 43, -38, 73, 29, 102)
              if blob.pixels() > max_size:
                  max_size = blob.pixels()
              max_blob=find_max(blobs)
              #print('sum :', len(blobs))
              output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy()) #方式1
              #print('you send:',output_str)
              #uart.write(output_str+'\r\n')
              print('not found!')
          if max_blob.cx() > 70 and max_blob.cx() <85:
             if max_blob.cy() <80:
                uart.write('s')
                print('s')
             if max_blob.cy() >80:
                uart.write('t')
                print('t')
          if max_blob.cx() < 70:
             uart.write('l')
             print('l')
          if max_blob.cx() >85:
             uart.write('r')
             print('r')
      ![0_1558342482724_报错.png](https://fcdn.singtown.com/b9b0a8cc-b0bc-4313-b519-2e138364081c.png)
