  • 为什么无法找到黄色和青色的圆形????
      # The below thresholds track in general red/green things. You may wish to tune them...
      #thresholds = [(49, 58, 64, 81, 12, 64), # generic_red_thresholds
                    #(81, 93, -82, -40, 17, 74), # generic_green_thresholds
                    #(60, 74, -13, 10, -63, -34),# generic_blue_thresholds
                    #(90, 95, -56, -32, -21, 4),# generic_qing_thresholds
                    #(80, 95, -21, 5, 34, 79),# generic_yellow_thresholds
                    #(3, 18, -7, 15, -15, 7),# generic_black_thresholds
                    #(60, 70, 30, 66, -64, -40) # generic_purple_thresholds
          for c in img.find_circles(threshold = 2000, x_margin = 5, y_margin = 5, r_margin = 10,
                  r_min = 5, r_max = 100, r_step = 2):
              #area为识别到的圆的区域,即圆的外接矩形框
              #img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 0))
              print(statistics)
              #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              if 49<statistics.l_mode()<58 and 65<statistics.a_mode()<81 and 12<statistics.b_mode()<64:#if the circle is red
                  img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 0))#识别到的红色圆形用红色的圆框出来
              elif 81<statistics.l_mode()<93 and -82<statistics.a_mode()<-40 and 17<statistics.b_mode()<74:
              elif 60<statistics.l_mode()<74 and -13<statistics.a_mode()<10 and -63<statistics.b_mode()<-34:
              elif 90<statistics.l_mode()<95 and -56<statistics.a_mode()<-32 and -21<statistics.b_mode()<4:
              elif 80<statistics.l_mode()<95 and -21<statistics.a_mode()<5 and 31<statistics.b_mode()<79:
              elif 3<statistics.l_mode()<18 and -7<statistics.a_mode()<16 and -15<statistics.b_mode()<7:
              elif 60<statistics.l_mode()<70 and 31<statistics.a_mode()<67 and -64<statistics.b_mode()<-40:
          print("FPS %f" % clock.fps())
    • This post is deleted!
    • @kidswong999 就是直接运行那个代码可以找到其他圆但是就是找不到青色和黄色的两种圆我才设置阈值的哦
    • 因为黄色的边缘不明显。threshold = 3500减小一点。
    • @kidswong999 我减小到1000了也是圈不出来哦。
