请问 神经网络中示例代码里面
有导入os模块,其中os模块里面导入了一个abc模块,python提示没有这abc个模块...网上也搜索不到这个模块的信息,去掉就运行不起来...看视频里面没有出现这个问题...或者说能不能提供一下abc.py的源码或者功能....请求帮助 \大哭
r"""OS routines for NT or Posix depending on what system we're on. This exports: - all functions from posix or nt, e.g. unlink, stat, etc. - os.path is either posixpath or ntpath - os.name is either 'posix' or 'nt' - os.curdir is a string representing the current directory (always '.') - os.pardir is a string representing the parent directory (always '..') - os.sep is the (or a most common) pathname separator ('/' or '\\') - os.extsep is the extension separator (always '.') - os.altsep is the alternate pathname separator (None or '/') - os.pathsep is the component separator used in $PATH etc - os.linesep is the line separator in text files ('\r' or '\n' or '\r\n') - os.defpath is the default search path for executables - os.devnull is the file path of the null device ('/dev/null', etc.) Programs that import and use 'os' stand a better chance of being portable between different platforms. Of course, they must then only use functions that are defined by all platforms (e.g., unlink and opendir), and leave all pathname manipulation to os.path (e.g., split and join). """ #' import abc import sys import stat as st _names = sys.builtin_module_names # Note: more names are added to __all__ later. __all__ = ["altsep", "curdir", "pardir", "sep", "pathsep", "linesep", "defpath", "name", "path", "devnull", "SEEK_SET", "SEEK_CUR", "SEEK_END", "fsencode", "fsdecode", "get_exec_path", "fdopen", "popen", "extsep"] def _exists(name): return name in globals() def _get_exports_list(module): try: return list(module.__all__) except AttributeError: return [n for n in dir(module) if n[0] != '_'] # Any new dependencies of the os module and/or changes in path separator # requires updating importlib as well. if 'posix' in _names: name = 'posix' linesep = '\n' from posix import * try: from posix import _exit __all__.append('_exit') except ImportError: pass import posixpath as path try: from posix import _have_functions except ImportError: pass import posix __all__.extend(_get_exports_list(posix)) del posix elif 'nt' in _names: name = 'nt' linesep = '\r\n' from nt import * try: from nt import _exit __all__.append('_exit') except ImportError: pass import ntpath as path import nt __all__.extend(_get_exports_list(nt)) del nt try: from nt import _have_functions except ImportError: pass else: raise ImportError('no os specific module found') sys.modules['os.path'] = path from os.path import (curdir, pardir, sep, pathsep, defpath, extsep, altsep, devnull) del _names if _exists("_have_functions"): _globals = globals() def _add(str, fn): if (fn in _globals) and (str in _have_functions): _set.add(_globals[fn]) _set = set() _add("HAVE_FACCESSAT", "access") _add("HAVE_FCHMODAT", "chmod") _add("HAVE_FCHOWNAT", "chown") _add("HAVE_FSTATAT", "stat") _add("HAVE_FUTIMESAT", "utime") _add("HAVE_LINKAT", "link") _add("HAVE_MKDIRAT", "mkdir") _add("HAVE_MKFIFOAT", "mkfifo") _add("HAVE_MKNODAT", "mknod") _add("HAVE_OPENAT", "open") _add("HAVE_READLINKAT", "readlink") _add("HAVE_RENAMEAT", "rename") _add("HAVE_SYMLINKAT", "symlink") _add("HAVE_UNLINKAT", "unlink") _add("HAVE_UNLINKAT", "rmdir") _add("HAVE_UTIMENSAT", "utime") supports_dir_fd = _set _set = set() _add("HAVE_FACCESSAT", "access") supports_effective_ids = _set _set = set() _add("HAVE_FCHDIR", "chdir") _add("HAVE_FCHMOD", "chmod") _add("HAVE_FCHOWN", "chown") _add("HAVE_FDOPENDIR", "listdir") _add("HAVE_FDOPENDIR", "scandir") _add("HAVE_FEXECVE", "execve") _set.add(stat) # fstat always works _add("HAVE_FTRUNCATE", "truncate") _add("HAVE_FUTIMENS", "utime") _add("HAVE_FUTIMES", "utime") _add("HAVE_FPATHCONF", "pathconf") if _exists("statvfs") and _exists("fstatvfs"): # mac os x10.3 _add("HAVE_FSTATVFS", "statvfs") supports_fd = _set _set = set() _add("HAVE_FACCESSAT", "access") # Some platforms don't support lchmod(). Often the function exists # anyway, as a stub that always returns ENOSUP or perhaps EOPNOTSUPP. # (No, I don't know why that's a good design.) ./configure will detect # this and reject it--so HAVE_LCHMOD still won't be defined on such # platforms. This is Very Helpful. # # However, sometimes platforms without a working lchmod() *do* have # fchmodat(). (Examples: Linux kernel 3.2 with glibc 2.15, # OpenIndiana 3.x.) And fchmodat() has a flag that theoretically makes # it behave like lchmod(). So in theory it would be a suitable # replacement for lchmod(). But when lchmod() doesn't work, fchmodat()'s # flag doesn't work *either*. Sadly ./configure isn't sophisticated # enough to detect this condition--it only determines whether or not # fchmodat() minimally works. # # Therefore we simply ignore fchmodat() when deciding whether or not # os.chmod supports follow_symlinks. Just checking lchmod() is # sufficient. After all--if you have a working fchmodat(), your # lchmod() almost certainly works too. # # _add("HAVE_FCHMODAT", "chmod") _add("HAVE_FCHOWNAT", "chown") _add("HAVE_FSTATAT", "stat") _add("HAVE_LCHFLAGS", "chflags") _add("HAVE_LCHMOD", "chmod") if _exists("lchown"): # mac os x10.3 _add("HAVE_LCHOWN", "chown") _add("HAVE_LINKAT", "link") _add("HAVE_LUTIMES", "utime") _add("HAVE_LSTAT", "stat") _add("HAVE_FSTATAT", "stat") _add("HAVE_UTIMENSAT", "utime") _add("MS_WINDOWS", "stat") supports_follow_symlinks = _set del _set del _have_functions del _globals del _add # Python uses fixed values for the SEEK_ constants; they are mapped # to native constants if necessary in posixmodule.c # Other possible SEEK values are directly imported from posixmodule.c SEEK_SET = 0 SEEK_CUR = 1 SEEK_END = 2 # Super directory utilities. # (Inspired by Eric Raymond; the doc strings are mostly his) def makedirs(name, mode=0o777, exist_ok=False): """makedirs(name [, mode=0o777][, exist_ok=False]) Super-mkdir; create a leaf directory and all intermediate ones. Works like mkdir, except that any intermediate path segment (not just the rightmost) will be created if it does not exist. If the target directory already exists, raise an OSError if exist_ok is False. Otherwise no exception is raised. This is recursive. """ head, tail = path.split(name) if not tail: head, tail = path.split(head) if head and tail and not path.exists(head): try: makedirs(head, exist_ok=exist_ok) except FileExistsError: # Defeats race condition when another thread created the path pass cdir = curdir if isinstance(tail, bytes): cdir = bytes(curdir, 'ASCII') if tail == cdir: # xxx/newdir/. exists if xxx/newdir exists return try: mkdir(name, mode) except OSError: # Cannot rely on checking for EEXIST, since the operating system # could give priority to other errors like EACCES or EROFS if not exist_ok or not path.isdir(name): raise def removedirs(name): """removedirs(name) Super-rmdir; remove a leaf directory and all empty intermediate ones. Works like rmdir except that, if the leaf directory is successfully removed, directories corresponding to rightmost path segments will be pruned away until either the whole path is consumed or an error occurs. Errors during this latter phase are ignored -- they generally mean that a directory was not empty. """ rmdir(name) head, tail = path.split(name) if not tail: head, tail = path.split(head) while head and tail: try: rmdir(head) except OSError: break head, tail = path.split(head) def renames(old, new): """renames(old, new) Super-rename; create directories as necessary and delete any left empty. Works like rename, except creation of any intermediate directories needed to make the new pathname good is attempted first. After the rename, directories corresponding to rightmost path segments of the old name will be pruned until either the whole path is consumed or a nonempty directory is found. Note: this function can fail with the new directory structure made if you lack permissions needed to unlink the leaf directory or file. """ head, tail = path.split(new) if head and tail and not path.exists(head): makedirs(head) rename(old, new) head, tail = path.split(old) if head and tail: try: removedirs(head) except OSError: pass __all__.extend(["makedirs", "removedirs", "renames"]) def walk(top, topdown=True, onerror=None, followlinks=False): """Directory tree generator. For each directory in the directory tree rooted at top (including top itself, but excluding '.' and '..'), yields a 3-tuple dirpath, dirnames, filenames dirpath is a string, the path to the directory. dirnames is a list of the names of the subdirectories in dirpath (excluding '.' and '..'). filenames is a list of the names of the non-directory files in dirpath. Note that the names in the lists are just names, with no path components. To get a full path (which begins with top) to a file or directory in dirpath, do os.path.join(dirpath, name). If optional arg 'topdown' is true or not specified, the triple for a directory is generated before the triples for any of its subdirectories (directories are generated top down). If topdown is false, the triple for a directory is generated after the triples for all of its subdirectories (directories are generated bottom up). When topdown is true, the caller can modify the dirnames list in-place (e.g., via del or slice assignment), and walk will only recurse into the subdirectories whose names remain in dirnames; this can be used to prune the search, or to impose a specific order of visiting. Modifying dirnames when topdown is false is ineffective, since the directories in dirnames have already been generated by the time dirnames itself is generated. No matter the value of topdown, the list of subdirectories is retrieved before the tuples for the directory and its subdirectories are generated. By default errors from the os.scandir() call are ignored. If optional arg 'onerror' is specified, it should be a function; it will be called with one argument, an OSError instance. It can report the error to continue with the walk, or raise the exception to abort the walk. Note that the filename is available as the filename attribute of the exception object. By default, os.walk does not follow symbolic links to subdirectories on systems that support them. In order to get this functionality, set the optional argument 'followlinks' to true. Caution: if you pass a relative pathname for top, don't change the current working directory between resumptions of walk. walk never changes the current directory, and assumes that the client doesn't either. Example: import os from os.path import join, getsize for root, dirs, files in os.walk('python/Lib/email'): print(root, "consumes", end="") print(sum([getsize(join(root, name)) for name in files]), end="") print("bytes in", len(files), "non-directory files") if 'CVS' in dirs: dirs.remove('CVS') # don't visit CVS directories """ top = fspath(top) dirs = [] nondirs = [] walk_dirs = [] # We may not have read permission for top, in which case we can't # get a list of the files the directory contains. os.walk # always suppressed the exception then, rather than blow up for a # minor reason when (say) a thousand readable directories are still # left to visit. That logic is copied here. try: # Note that scandir is global in this module due # to earlier import-*. scandir_it = scandir(top) except OSError as error: if onerror is not None: onerror(error) return with scandir_it: while True: try: try: entry = next(scandir_it) except StopIteration: break except OSError as error: if onerror is not None: onerror(error) return try: is_dir = entry.is_dir() except OSError: # If is_dir() raises an OSError, consider that the entry is not # a directory, same behaviour than os.path.isdir(). is_dir = False if is_dir: dirs.append(entry.name) else: nondirs.append(entry.name) if not topdown and is_dir: # Bottom-up: recurse into sub-directory, but exclude symlinks to # directories if followlinks is False if followlinks: walk_into = True else: try: is_symlink = entry.is_symlink() except OSError: # If is_symlink() raises an OSError, consider that the # entry is not a symbolic link, same behaviour than # os.path.islink(). is_symlink = False walk_into = not is_symlink if walk_into: walk_dirs.append(entry.path) # Yield before recursion if going top down if topdown: yield top, dirs, nondirs # Recurse into sub-directories islink, join = path.islink, path.join for dirname in dirs: new_path = join(top, dirname) # Issue #23605: os.path.islink() is used instead of caching # entry.is_symlink() result during the loop on os.scandir() because # the caller can replace the directory entry during the "yield" # above. if followlinks or not islink(new_path): yield from walk(new_path, topdown, onerror, followlinks) else: # Recurse into sub-directories for new_path in walk_dirs: yield from walk(new_path, topdown, onerror, followlinks) # Yield after recursion if going bottom up yield top, dirs, nondirs __all__.append("walk") if {open, stat} <= supports_dir_fd and {scandir, stat} <= supports_fd: def fwalk(top=".", topdown=True, onerror=None, *, follow_symlinks=False, dir_fd=None): """Directory tree generator. This behaves exactly like walk(), except that it yields a 4-tuple dirpath, dirnames, filenames, dirfd `dirpath`, `dirnames` and `filenames` are identical to walk() output, and `dirfd` is a file descriptor referring to the directory `dirpath`. The advantage of fwalk() over walk() is that it's safe against symlink races (when follow_symlinks is False). If dir_fd is not None, it should be a file descriptor open to a directory, and top should be relative; top will then be relative to that directory. (dir_fd is always supported for fwalk.) Caution: Since fwalk() yields file descriptors, those are only valid until the next iteration step, so you should dup() them if you want to keep them for a longer period. Example: import os for root, dirs, files, rootfd in os.fwalk('python/Lib/email'): print(root, "consumes", end="") print(sum([os.stat(name, dir_fd=rootfd).st_size for name in files]), end="") print("bytes in", len(files), "non-directory files") if 'CVS' in dirs: dirs.remove('CVS') # don't visit CVS directories """ if not isinstance(top, int) or not hasattr(top, '__index__'): top = fspath(top) # Note: To guard against symlink races, we use the standard # lstat()/open()/fstat() trick. if not follow_symlinks: orig_st = stat(top, follow_symlinks=False, dir_fd=dir_fd) topfd = open(top, O_RDONLY, dir_fd=dir_fd) try: if (follow_symlinks or (st.S_ISDIR(orig_st.st_mode) and path.samestat(orig_st, stat(topfd)))): yield from _fwalk(topfd, top, isinstance(top, bytes), topdown, onerror, follow_symlinks) finally: close(topfd) def _fwalk(topfd, toppath, isbytes, topdown, onerror, follow_symlinks): # Note: This uses O(depth of the directory tree) file descriptors: if # necessary, it can be adapted to only require O(1) FDs, see issue # #13734.
@kidswong999 这个是神经网络示例里面导入的os库,显示没有abc模块
这个不是OpenMV上的程序。
虽然很抱歉打扰,但是这个确实是你们的模块导入的os文件,然后再在os文件里面导入的abc文件...
os模块是内置在OpenMV的,不是你提供的代码。
@kidswong999 哦哦,谢谢....能不能给一下os文件...我从git上面下了一个,发现它用了wifi模块...
@mtfs 没有os文件。os是内置在OpenMV的,不需要额外添加。
