  • 先识别红再识别绿后识别蓝,没有识别,则等待。求助
    • 在问下thresholds = [(32, 48, 54, 70, 31, 59),
      (28, 71, -128, -24, 13, 42),
      (38, 62, -7, 31, -79, -41)]如何按顺序去识别呢,比如先识别红,没有识别到则等待,有就继续,绿以此类推
    • @kidswong999 需要判断颜色的code()吗
    • @13542749802 不需要
    • @kidswong999
      #初始化串口3
      uart = UART(3,115200)
      uart.init(115200,bits = 8,parity = None,stop = 1)
      #初始化RGB
      red_led = pyb.LED(1)
      grean_led = pyb.LED(2)
      blue_led = pyb.LED(3)
      #关闭RGB灯
      red_led.off()
      grean_led.off()
      blue_led.off()
      red_color = (32, 48, 54, 70, 31, 59) # 一般情况下的红色阈值
      grean_color  = (42, 71, -63, -29, 16, 42) # 一般情况下的绿色阈值
      blue_color = (38, 62, -7, 31, -79, -41) # 一般情况下的蓝色阈值
      # 标记当前识别的颜色
      def markCurColor(img, cName, cRgb):
          img.draw_string(0, 0, cName, color = cRgb)
      # 如果是红色,执行此函数
      def doWithRed(img):
          markCurColor(img, "RED", (255, 0, 0))
          red_led.on()
          grean_led.off()
          blue_led.off()
          uart.write("red_ok\r\n")
      # 如果是绿色,执行此函数
      def doWithGreen(img):
          markCurColor(img, "GREEN", (0, 255, 0))
          grean_led.on()
          red_led.off()
          blue_led.off()
          uart.write("grean_ok\r\n")
      # 如果是绿色,执行此函数
      def doWithBlue(img):
          markCurColor(img, "BLUE", (0, 0, 255))
          blue_led.on()
          red_led.off()
          grean_led.off()
          uart.write("blue_ok\r\n")
      # 比较两个色块大小的函数
      def compareBlob(blob1, blob2):
          tmp = blob1.pixels() - blob2.pixels()
          if tmp == 0:
              return 0;
          elif tmp > 0:
              return 1;
              return -1;
      def fun():
              if uart.any():
                  uart_buf = uart.readline()
                  print(uart_buf)
                  if uart_buf == b'0x01':
                      sensor.set_auto_gain(False)
                      sensor.set_auto_exposure(False, 1500)#这里设置曝光时间
                          red_blob = img.find_blobs([red_color], pixels_threshold=200, area_threshold=200, merge=True)
                          if red_blob:
                              for blob in red_blob:
                                      doWithRed(img)
                              blue_led.off()
                              red_led.off()
                              grean_led.off()
                          grean_blob = img.find_blobs([grean_color], pixels_threshold=200, area_threshold=200, merge=True)
                          if grean_blob:
                              for blob in grean_blob:
                                      doWithGreen(img)
                              blue_led.off()
                              red_led.off()
                              grean_led.off()
                          blue_blob = img.find_blobs([blue_color], pixels_threshold=200, area_threshold=200, merge=True)
                          if blue_blob:
                              for blob in blue_blob:
                                      doWithBlue(img)
                              blue_led.off()
                              red_led.off()
                              grean_led.off()
                  if uart_buf == b'0x02':
                      pase
      if __name__=='__main__':
          fun()
      按你那样,为什么我这里的绿色就识别不到了,但是只判断绿色的话就识别的到
    • @13542749802 你的代码有两个死循环
