星瞳实验室APP,快速收到回复
  • 脱机运行为何串口无法发送?
    • 本问题不涉及代码,我使用了WIFI扩展板,OPENMV直接插在电脑上供电可以在串口上打印值,但是接在充电宝上虽然仍可连接WIFI,仍可看到图像,但是串口无法打印数值。同样的代码同样的操作重复多次仍是如此,是因为电压问题吗?该如何解决呢?
    • 应该是代码的问题。请提供你的代码。
    • import sensor, image, time, math, network, usocket, sys
      uart = UART(3, 9600, timeout_char=1000)
      SSID ='OPENMV_AP'
      KEY  ='1234567890'
      HOST = ''
      PORT = 8080
      threshold_index = 0
      thresholds = [(20, 93, -59, -22, -5, 32)]
      sensor.set_auto_gain(False)
      sensor.set_brightness(1)
      sensor.set_saturation(1)
      def start_streaming(s):
      	client, addr = s.accept()
      	client.settimeout(2.0)
      	data = client.recv(1024)
      				"Server: OpenMV\r\n" \
      				"Pragma: no-cache\r\n\r\n")
      		frame = sensor.snapshot()
      		header = "\r\n--openmv\r\n" \
      		client.send(header)
      		client.send(cframe)
      		for blob in img.find_blobs([thresholds[threshold_index]], pixels_threshold=200, area_threshold=200, merge=True):
      			middle = blob.cx()
      			print(middle)
      			if middle>=0 and middle<=70:
      				feedback = '0x02'
      				id = int('0x02',16)
      				uart.writechar(id)
      			elif middle>=90 and middle<=160:
      				id = int('0x00',16)
      				uart.writechar(id)
      			else :
      				id = int('0x06',16)
      				uart.writechar(id)
      		s.bind([HOST, PORT])
      		s.listen(5)
      		s.settimeout(3)
      		start_streaming(s)
      	except OSError as e:
      		s.close()
      		print("socket error: ", e)
    • 这个是代码,经反复测试在电脑端供电可正常使用,用充电宝供电虽WIFI模块正常工作,但串口无数据发送,急求解决办法,谢谢
