  • 关于分别模板匹配每个roi区域共5个区域并输出结果的程序,代码错在哪里?
      img.draw_rectangle((5,50,25,35),color = (0, 0, 0))
      img.draw_rectangle((30,50,25,35),color = (0, 0, 0))
      img.draw_rectangle((55,50,25,35),color = (0, 0, 0))
      img.draw_rectangle((80,50,25,35),color = (0, 0, 0))
      img.draw_rectangle((105,50,25,35),color = (0, 0, 0))
      templates = ["/0.pgm", "/1.pgm", ] #保存多个模板
      a=0 #依次对每个共5个roi区域进行模板匹配,得出结果
      if a==0:
      for t in templates:
      template = image.Image(t)
      #对每个模板遍历进行模板匹配
      r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) , roi=(5, 50, 25, 35))
      if r:
      img.draw_rectangle(r, color=0)
      print(t)
      a+=1
      elif a==1:
      for t in templates:
      r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) , roi=(30, 50, 25, 35))
      if r:
      print(t)
      a+=1
      elif a==2:
      for t in templates:
      r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) , roi=(55, 50, 25, 35))
      if r:
      print(t)
      a+=1
      elif a==3:
      for t in templates:
      r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) , roi=(80, 50, 25, 35))
      if r:
      print(t)
      a+=1
      else a==4:
      for t in templates:
      r = img.find_template(template, 0.70, step=4, search=SEARCH_EX) , roi=(105, 50, 25, 35))
      if r:
      print(t)
      a=0
      #print(clock.fps())
    • 代码出现什么错误?
    • 此回复已被删除!
    • @kidswong999
          if a==0:
              for t in templates:
                  #对每个模板遍历进行模板匹配
                 r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=(5, 50, 25, 35))
                 if r:
                      img.draw_rectangle(r)
                      print(t)
                      a+=1
          elif a==1:
              for t in templates:
                 r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=(30, 50, 25, 35))
                 if r:
                    print(t)
                    a+=1
          elif a==2:
               for t in templates:
                 r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=(55, 50, 25, 35))
                 if r:
                      print(t)
                      a+=1
          elif a==3:
               for t in templates:
                   r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=(80, 50, 25, 35))
                   if r:
                       print(t)
                       a+=1
               for t in templates:
                   r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=(105, 50, 25, 35))
                   if r:
                      print(t)
                      a=0
    • @kidswong999 程序只能识别第一位的0,是逻辑错误吗
    • 你的逻辑很奇怪,遍历区域直接for循环就行。那个a加来加去没意义。
      rois = [(5, 50, 25, 35),(30, 50, 25, 35),(55, 50, 25, 35),(80, 50, 25, 35),(105, 50, 25, 35)]
      for roi in rois:
          for t in templates:
               r = img.find_template(template, 0.70, step=4, search=SEARCH_EX, roi=roi)
               if r:
                   print(t)
