  • 串口接收数据,程序只执行一下子,openmv直接卡死,报错
      a=0
          print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
          #code = 'A'
          #print(code)
          #uart.write(code)
          if uart.any():
              recieve = uart.readline().decode().strip()
              print(recieve)
          if recieve == 'L':
              print("We win.")
              a=a+1
              print(a)
              print("\n")
              print("No FOUND")
    • 传递过来的数据是‘L\n’
    • 你的代码不对,if recieve == 'L':应该在if uart.any():里面。
      a=0
          #code = 'A'
          #print(code)
          #uart.write(code)
          if uart.any():
              print(recieve)
              if recieve == 'L':
                  print("We win.")
                  a=a+1
                  print(a)
                  print("\n")
              print("No FOUND")
      我用串口助手发送数据,没发现问题。
