  • 判断色块坐标是否在画面中心坐标一定范围内,报错?希望能看下我这逻辑代码是否可以?
    • # Blob Detection Example
      import sensor, image, time, pyb,mjpeg
      from pyb import UART,Pin,Timer
      import utime
      uart=pyb.UART(3,115200,timeout_char=1000)
      p_out = Pin('P7',Pin.OUT_PP)
      p_out.low()
      blue_threshold_01 = (0, 100, -16, 127, -128, -31)
      #设置蓝色的阈值,括号里面的数值分别是L A B 的最大值和最小值(minL, maxL, minA,
      #设置(min, max)两个数字即可。
      sensor.set_framesize(sensor.QVGA) # use QVGA for quailtiy ,use QQVGA for speed.
        扩宽roi
      def expand_roi(roi):
          # set for QQVGA 160*120
          extra = 5
          win_size = (160, 120)
          (x, y, width, height) = roi
          new_roi = [x-extra, y-extra, width+2*extra, height+2*extra]
          if new_roi[0] < 0:
              new_roi[0] = 0
          if new_roi[1] < 0:
              new_roi[1] = 0
          if new_roi[2] > win_size[0]:
              new_roi[2] = win_size[0]
          if new_roi[3] > win_size[1]:
              new_roi[3] = win_size[1]
          return tuple(new_roi)
          #  pixels_threshold=100, area_threshold=100
          blobs = img.find_blobs([blue_threshold_01], area_threshold=150)
          #如果找到了目标颜色
            # print(blobs)
             #迭代找到的目标颜色区域
                  is_circle = False
                  max_circle = None
                  max_radius = -1
                  new_roi = expand_roi(blob.rect())
                  for c in img.find_circles(threshold = 2000, x_margin = 20, y_margin = 20, r_margin = 10, roi=new_roi):
                      is_circle = True
                      # img.draw_circle(c.x(), c.y(), c.r(), color = (255, 255, 255))
                      if c.r() > max_radius:
                          max_radius = c.r()
                          max_circle = c
                  if is_circle:
                      # 如果有对应颜色的圆形 标记外框
                      img.draw_rectangle(new_roi) # rect
                      img.draw_rectangle(blob.rect()) # rect
                      #用矩形标记出目标颜色区域
                      img.draw_cross(blob[5], blob[6]) # cx, cy
                      img.draw_circle(max_circle.x(), max_circle.y(), max_circle.r(), color = (0, 0, 255))
                      img.draw_circle(max_circle.x(), max_circle.y(), max_circle.r() + 1, color = (0, 0, 255))
                      print(blob[5], blob[6])
                      z=100
                      x_h=(blob[5]>>8)&0xff
                      x_l=blob[5]&0xff
                      y_h=(blob[6]>>8)&0xff
                      y_l=blob[6]&0xff
                      z_h=(z>>8)&0xff
                      z_l=z&0xff
                      data=bytearray([0x02,x_h,x_l,y_h,y_l,z_h,z_l,0x06,0x0D,0X0A])
                      print('you send:',data)
                      uart.write(data)
                  if (sensor.width/2 -10<=blob[5]<=sensor.width/2 +10) and (sensor.height/2 -10<=blob[6]<=sensor.height/2 +10):
                      z=50
                      x_l=blob[5]&0xff
                      y_l=blob[6]&0xff
                      z_h=(z>>8)&0xff
                      z_l=z&0xff
                      data1=bytearray([0x02,x_h,x_l,y_h,y_l,z_h,z_l,0x06,0x0D,0X0A])
                      print('you send:',data1)
                      uart.write(data1)
                      timesleep(1000)
                      timesleep(1000)
                      timesleep(1000)
                      z=0
                      x_l=blob[5]&0xff
                      y_l=blob[6]&0xff
                      z_h=(z>>8)&0xff
                      z_l=z&0xff
                      data2=bytearray([0x02,x_h,x_l,y_h,y_l,z_h,z_l,0x06,0x0D,0X0A])
                      print('you send:',data2)
                      uart.write(data2)
                      #p_out.high()
          # connected to your computer. The FPS should increase once disconnected.!
      0_15563372ng
    • sensor.width是个啥?
      函数调用要用括号。
      sensor.width()
