STM32与OPenmv之间通信,二者单独运行可以,连在一起没现象啊,求大佬指点?
import sensor, image,time import json from pyb import UART sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... clock = time.clock() uart = UART(3, 115200) #uart.init(19200, bits=8, parity=None, stop=1) #8位数据位,无校验位,1位停止位 while(True): clock.tick() img = sensor.snapshot() img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens. for code in img.find_qrcodes(): img.draw_rectangle(code.rect(), color = (255, 0, 0)) message = code.payload() uart.write(message) print(code) else: print("not found!") #if message == "abc" : # num = 1 # uart.write(num) # print(message) # time.sleep(1000) #if message == "def" : # uart.write('2') # time.sleep(1000) ```stm32代码 void LED_RED(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //使能PB,PE端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //LED0-->PB.5 端口配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化GPIO GPIO_SetBits(GPIOB,GPIO_Pin_5); //PE.5 输出高 GPIO_ResetBits(GPIOB,GPIO_Pin_5); } void USART1_IRQHandler(void) { u8 res; if(USART_GetITStatus(USART1,USART_IT_RXNE)) { res= USART_ReceiveData(USART1); USART_SendData(USART1,res); //huan hang if(res=='1') { res='a'; USART_SendData(USART1,res); LED_RED(); //liang Delay(5000000); } if(res=='2') { res='b'; USART_SendData(USART1,res); LED_CLOSE(); //mie Delay(5000000); } // if(res=='3') // { // res='c'; // USART_SendData(USART1,res); // } } } int main(void) { LED_CLOSE(); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); My_USART1_Init(); USART1_IRQHandler(); LED_CLOSE(); while(1); }
先用TTL转串口模块,或者
串口调试扩展板
调试,看看串口助手里有没有数据。
可能是线没连好,或者代码写错了,都有可能。
@kidswong999 串口里面是有数据的
@kidswong999 是stm32的接受协议错了吗??
你说二者单独运行可以,请提供“可以”的截图,比如串口助手的截图。
