追踪色块时,小车转角过大,可能是什么原因造成的?
# Blob Detection Example # # This example shows off how to use the find_blobs function to find color # blobs in the image. This example in particular looks for dark red objects. import sensor, image, time#导入感光元件,图像,时钟模块 import car from pid import PID # You may need to tweak the above settings for tracking red things... # Select an area in the Framebuffer to copy the color settings. #常规设置 sensor.reset() # Initialize the camera sensor.重置图像分辨率 sensor.set_pixformat(sensor.RGB565) # use RGB565.设置图像为RGB565,彩色 sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect.跳过几帧,使以上设置生效 sensor.set_auto_whitebal(False) # turn this off.设置白平衡关闭;颜色识别时,要关闭白平衡,避免影响识别 clock = time.clock() # Tracks FPS.跟踪快照之间经过的毫秒数 # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... #设置图像阈值,根据需要修改 blue_threshold = (52, 13, 34, -3, -26, -51) ''' 标准参数; 作用是如果摄像头检测到的小球的色块的像素点数>2000的话,说明我们的小车距离我们的小球很近 >2000,就使小车后退一点,和小球保持一段距离 <2000,就使小车追踪这个小车 ''' size_threshold = 2000 #自定义 #x_pid是方向pid,控制电机的方向 #如果小车转动的角度过大,可以调整'p'参数小一点 #???只传入p, i参数,imax代表??? x_pid = PID(p=0.2, i=1, imax=100) #h_pid是距离pid,控制小车的速度 #如果小车的速度过快,可以调整'p'参数小一点 h_pid = PID(p=0.02, i=0.1, imax=50) #find_max函数找到视野中面积最大的小球 #在视野中出现不止一个小球,找到面积最大,即最近的小球; def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() # Track elapsed milliseconds between snapshots().跟踪快照之间经过的毫秒数 #从sensor中截取一段图像 img = sensor.snapshot() # Take a picture and return the image. #调用颜色识别的函数 blobs = img.find_blobs([blue_threshold]) if blobs: #如果找到色块 max_blob = find_max(blobs)#找到最大的色块去追踪 #pid的差值,用于计算后面pid的参数 x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) ''' for b in blobs: # Draw a rect around the blob. img.draw_rectangle(b[0:4]) # rect img.draw_cross(b[5], b[6]) # cx, cy ''' img.draw_rectangle(max_blob[0:4]) # rect 在找到的色块上划矩形 img.draw_cross(max_blob[5], max_blob[6]) # cx, cy 在找到的色块上划十字 #通过传参给pid函数,得到结果,放回控制小车的参数 x_output=x_pid.get_pid(x_error,1)#传入误差值和积分参数 h_output=h_pid.get_pid(h_error,1) print("h_output",h_output) #小车的距离pid一致,方向pid相反 car.run(-h_output-x_output,-h_output+x_output) #未找到色块则慢速原地旋转,寻找四周的色块 else: car.run(0,0)
代码主要是教程里的,改了几个参数而已。
在追踪色块时,我固定好蓝色色块,让小车靠近,然后PID控制的时候有点奇怪,小车会偏向右边(或左边)直到固定的色块不在镜头范围内。我的电机是12v620转的。
如果不是标准的小车,没有硬件我没办法判断。
硬件:电机25GA370直流减速电机,tb6612驱动芯片,电源模块,电池,openmv
没有硬件我没办法判断。
