特征点识别中出的问题
我提前三个特征点保存到SD中,在进行模板匹配的时候调用为什么会出现错误
import sensor, time, image sensor.reset() sensor.set_contrast(3) sensor.set_gainceiling(16) sensor.set_framesize(sensor.VGA) sensor.set_windowing((320, 240)) sensor.set_pixformat(sensor.GRAYSCALE) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False, value=100) def draw_keypoints(img, kpts): if kpts: print(kpts) img.draw_keypoints(kpts) img = sensor.snapshot() time.sleep(1000) kpts1 = image.load_descriptor("/zhixing.orb") kpts2 = image.load_descriptor("/youzhaun.orb") kpts3 = image.load_descriptor("/zuozhuan.orb") clock = time.clock() while (True): clock.tick() img = sensor.snapshot() kpts0 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=True) if (kpts1): match = image.match_descriptor(kpts0,kpts1,threshold=85) if (match.count()>10): img.draw_rectangle(match.rect()) img.draw_cross(match.cx(), match.cy(), size=10) print(1) if (kpts2): match = image.match_descriptor(kpts0, kpts2,threshold=85) if (match.count()>10): img.draw_rectangle(match.rect()) img.draw_cross(match.cx(), match.cy(), size=10) if (kpts3): match = image.match_descriptor(kpts0, kpts2, threshold=85) if (match.count()>10): img.draw_rectangle(match.rect()) img.draw_cross(match.cx(), match.cy(), size=10
