请问这是摄像头读取不了颜色吗?可以读取的红色、绿色一类的都显示了LAB,但是黄色就显示fps,怎么解决呢???
@kidswong999 你好,请问是不是黄色摄像头不读?为啥这样显示呢?
你代码写错了,请提供代码。
import sensor, image, time sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() while(True): clock.tick() img = sensor.snapshot().lens_corr(1.8) for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10, r_min = 2, r_max = 100, r_step = 2): area = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r()) #area为识别到的圆的区域,即圆的外接矩形框 statistics = img.get_statistics(roi=area)#像素颜色统计 print(statistics) #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。 #l_mode(),a_mode(),b_mode()是L通道,A通道,B通道的众数。 if 0<statistics.l_mode()<100 and 0<statistics.a_mode()<127 and 0<statistics.b_mode()<127:#if the circle is red img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来 elif 0<statistics.l_mode()<100 and -64<statistics.a_mode()<-8 and -32<statistics.b_mode()<32:#if the circle is graeen img.draw_circle(c.x(), c.y(), c.r(), color = (0, 255, 0))#识别到的绿色圆形用绿色的圆框出来 elif 65<statistics.l_mode()<80 and -10<statistics.a_mode()<10 and 60<statistics.b_mode()<70:#if the circle is red img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 255))#识别到的黄色圆形用蓝色的圆框出来 else: img.draw_rectangle(area, color = (255, 255, 255)) #将非红色的圆用白色的矩形框出来 print("FPS %f" % clock.fps())
@kidswong999 黄色的不是LAB的阈值问题,就是摄像头读取不了,显示不出来。
http://book.openmv.cc/example/09-Feature-Detection/find-circles.html
单独运行这个程序应该会把圆形圈出来。
应该是在LAB中,颜色和背景颜色太近,我把threshold = 1500,很容易有误判。
