用到一个定时器,一个pwm,出现报错
用到一个定时器,一个pwm,出现报错ValueError: Pin(D12) doesn't have an af for Timer(2)
import sensor, image, time from pyb import Pin, Timer,LED sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) # Wait for settings take effect. RUN = LED(4) STATUE = LED(1) tim = Timer(4, prescaler=83,period=370) #驱动蜂鸣器 def BeepOn(): tim.channel(1, Timer.PWM, pin=Pin("P7"), pulse_width=187) #关闭蜂鸣器 def BeepOff(): tim.channel(1,Timer.PWM, pin=Pin("P7"), pulse_width=0) def tick(timer): # we will receive the timer object when being called RUN.toggle() tim = Timer(2, freq=1) # create a timer object using timer 4 - trigger at 1Hz tim.callback(tick) # set the callback to our tick function BeepOn() while(True): img = sensor.snapshot() # Take a picture and return the image. # to the IDE. The FPS should increase once disconnected.
