  • 单片机先给op发送N识别红并返回给串口坐标但再次发送G识别绿的时候就不行了请问串口数据的发送会占用字符串的识别吗?
    • while (1):
          if uart.any():
              receive=uart.readline().decode()
              if receive=='N':                #when receive 'N',begin to find the color
                  threshold_index=0           #red for 0
                  print(receive)
                      blobs = img.find_blobs([thresholds[threshold_index]])
                          max_blob=find_max(blobs)
                          aim=1                #1 find the aim,0 not find
                          a=max_blob.cx()
                          b=max_blob.cy()
                          #transfer the format become(x,xxx,xxx)
                          if max_blob.cx()<10:
                              a='00'+str(a)
                              if max_blob.cy()<10:
                                  b='00'+str(b)
                          elif max_blob.cy()<10:
                              b='00'+str(b)               #the case that max_blob.cx or .cy<10
                          elif max_blob.cx()<100:
                              a='0'+str(a)
      #                         print(a)
                              if max_blob.cy()<100:
                                  b='0'+str(b)
                          elif max_blob.cy()<100:
                              b='0'+str(b)                #the case that max_blob.cx or .cy<100
                          output_str="[%s,%s,%s]" % (aim,a,b)
                          print('you send:',output_str)
                          uart.write(output_str+'\r\n')      #the output foemat is (x,xxx,xxx)
                          aim=0
                          aim="[%s]"%(aim)
                          uart.write(aim+'\r\n')
                          print('not found!')
                      if uart.any():
                          receiv=uart.readline().decode()
                          if receiv=='G':                  #the command is the symbol of find green
                              threshold_index=2            #green for 2
                                      a=max_blob.cx()
                                      b=max_blob.cy()
                                          a='00'+str(a)
                                              b='00'+str(b)
                                          a='0'+str(a)
                                          print(a)
                                              b='0'+str(b)
                                      print('send:',output_str)
                                      aim=0
                                      aim="[%s]"%(aim)
                                      print('not found!')
    • 你的 if receive=='N'里面又有一个死循环。
