  • 如何在一个程序调用另一个程序的一个结果
    • 我不知道你这代码是个啥...
      不过你的引号打错了
    • 我想调用另一个程序的一个结果
      # Scan Example
      # This example shows how to scan for networks with the WiFi shield.
      import time, network
      SSID='TP-LINK_6A73' # Network SSID
      KEY='12345678'  # Network key
      wlan = network.WINC()
      print("\nFirmware version:", wlan.fw_version())
          print(wlan.ifconfig())
          scan_result = wlan.scan()
          for ap in scan_result:
              print("Channel:%d RSSI:%d Auth:%d BSSID:%s SSID:%s"%(ap))
              a=(ap[1])
              b = (ap[4])
              if a>=-60:
                    d=print("Channel:%d RSSI:%d Auth:%d BSSID:%s SSID:%s"%(ap))
                    print("信号强度:%d"%a)
                    print ('SSID:%s'%b)
          time.sleep(5000)
      这是第一个程序,想在下面这个程序中调用d,并想让下面这个程序连上这个WiFi
      SSID ='206-1' # Network SSID
      KEY ='12345678' # Network key
      HOST ='0.0.0.0' # Use first available interface
      Reset sensor
      sensor.set_contrast(1) #设置相机图像的对比度。-3至+3
      sensor.set_brightness(1) #设置相机图像亮度。-3至+3
      sensor.set_saturation(1) #设置相机图像饱和度。 —3至+3
      sensor.set_gainceiling(16) #设置相机图像增益上限 2,4,6,8,16,32,64,128
      sensor.set_framesize(sensor.QQVGA) #设置相机模块的帧大小
      Init wlan module and connect to network
      print("Trying to connect... (may take a while)...")
      import sys
      sys.path.append('C:\Users\DELL\Desktop\a.py')
      import a
      a.d()
      We should have a valid IP now via DHCP
      Create server socket
      Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
      Set server socket to non-blocking
      s.settimeout(0)
      def start_streaming(s):
      client, addr = s.accept()
      client.settimeout(2.0)
      # Read request from client
      data = client.recv(1024)
      # Send multipart header
                  "Server: OpenMV\r\n" \
                  "Pragma: no-cache\r\n\r\n")
      # FPS clock
      # Start streaming images
          frame = sensor.snapshot()
          header = "\r\n--openmv\r\n" \
          client.send(header)
          client.send(cframe)
      start_streaming(s)
      except OSError as e:
      print("socket error: ", e)
      #sys.print_exception(e)
      请问具体怎么做
    • 写在一个程序里。
    • 是不是不支持调用啊
    • 不是你理解的程序调用。
      OpenMV的编程思路是函数,不是程序文件。
