  • 接受几次数据后就卡死了
      uart = UART(3,4800, timeout_char=1000) # i使用给定波特率初始化
      uart.init(4800, bits=8, parity=None, stop=1, timeout_char=1000) # 使用给定参数初始化
      GRAYSCALE_THRESHOLD = [(0, 64)]
      ROIS = [ # [ROI, weight]
      (0, 0, 1, 1, 1), # You'll need to tweak the weights for your app
      (0, 50, 320, 30, 1), # depending on how your robot is setup.
      (0, 0, 1, 1, 1)
      weight_sum = 0
      for r in ROIS: weight_sum += r[4]
      sensor.set_contrast(3)
      sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
      sensor.set_framesize(sensor.VGA) # use QQVGA for speed.
      sensor.set_auto_gain(False,value=100) # must be turned off for color tracking
      a=0
      if kpts:
      print(kpts)
      img.draw_keypoints(kpts)
      time.sleep(1000)
      kpts1 = image.load_descriptor("/desc.orb")
      def high(x):
      x=x>>8
      return x
      def low(x):
      x=x&0xff
      return x
      print(1)
      if uart.any():
      a=int(uart.readchar())
      print(a)
      请在这里粘贴代码
    已锁定
