报错是unindent does not match any outer indentation level?
print(output)那行ide里是对齐的,但是粘贴之后是不对齐的? THRESHOLD = (36, 83, -43, 49, 60, -73) import sensor, image, time from pyb import LED from pyb import UART from pyb import delay from pid import PID uart = UART(3, 9600, timeout_char=1000) rho_pid = PID(p=0.4, i=0) theta_pid = PID(p=0.001, i=0) LED(1).on() LED(2).on() LED(3).on() sensor.reset() sensor.set_vflip(True) sensor.set_hmirror(True) sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQQVGA) sensor.skip_frames(time = 2000) clock = time.clock() while(True): clock.tick() img = sensor.snapshot().binary([THRESHOLD]) line = img.get_regression([(100,100,0,0,0,0)], robust = True) if (line): rho_err = abs(line.rho())-img.width()/2 if line.theta()>90: theta_err = line.theta()-180 else: theta_err = line.theta() img.draw_line(line.line(), color = 127) #print(rho_err,line.magnitude(),rho_err) if line.magnitude()>8: rho_output = rho_pid.get_pid(rho_err,1) theta_output = theta_pid.get_pid(theta_err,1) output = rho_output+theta_output uart.write('$'+str(int(output))+'&') print(output) delay(50) else: pass
缩进是错的。
粘贴之后是不对齐的,说明本来就不是对齐的。
